MSFT Sync 4.4 download file
Sending as I type.
a11m1ghty, if you require Siri, then 4.4 is for you. If not, 4.6.
I have both. Take your pick.
Sent. Check your email.
Do you have the 4.4 file? I have 4.6 and my Siri does not work anylonger. You seem to be the only one that has this file still. zachcbarrett @ yahoo.com
Zach,
File sent. Look for email from WeTransfer.
Hello SGilbert,
Yesterday I decided to update my SYNC in my 2010 Mercury Milan with Navigation and Now I can't get my bluetooth working correctly?
I installed this version: DE8T-14D544-AD (I think this is 4.6)
Any chance you have a version that will work for me? 4.4?
THanks
email clifford5555 at Rocketmail
The 4.6 that I have is called: DR3T-14D544-AG
I also have 4.4.1 called: Gen1v441buildEE2824updatefromv3263packageRev2
I have no idea whether these would work on your Mercury, but you may have either if you want.
Thanks for the quick reply!
I guess I'm not sure if I should try installing your 4.4 or not. Let me give you the details:
My 2010 Milan is Hybrid also! It has touch screen, single CD, Navigation, Voice Commands.
it was on original software and my bluetooth would connect and work like it supposed to. but it would not display the song information form my phone.
Now after update I have to click on 2 screens and select BT mode to get my phone to work in the car. Default to Line In is terrible programming. It did fix the song info on the screen, but now it is a pain to mess with every time I get in my car.
I drive it for Uber, so it is really annoying.
I have searched all over the web and can not find a solution to download older version to fix both my problems. Lots of info for 2013+, but nothing much for 2010-2012
If your file is not compatible will my car tell me or will it just break it?
"If your file is not compatible will my car tell me or will it just break it?"
I cannot answer that--no idea. Perhaps those more knowledgeable than I will know.
My 4.4.1 file is named:
Gen1v441buildEE2824updatefromv3263packageRev2.zip
I have no idea what you are asking for, but mine is not it. Will mine work--absolutely no clue!
Yeah, that name is completely different. :oops:
The 4.4 version I’m looking for has the following files inside the SyncMyRide folder:
8L2T-14D546-AF.cab
DE8T-14D544-AC.sec
E1BT-14D546-AA.cab
E1BT-14D546-BB.cab
E1BT-14D546-CA.cab
E1BT-14D546-FB.cab
E1BT-14D546-GA.cab
E1BT-14D546-HC.CAB
FJ5T-14D546-AAA.pks
If you’re willing to send yours to me, I can take a look at the update files inside the zip file and see if it is the same as what I’m looking for. At this point, there’s not much to lose for me as I have not been able to find the AC file anywhere.
I will need an email address.
FWIW-What vehicle & year is this for?
2012 Lincoln MKZ
danke
