Just had to have our Aviator battery replaced after three years and 24K miles. Never went into deep sleep mode or displayed any messages, but electrical features gradually stopped working one at a time. The progression was: vehicle would not wake up on approach, vehicle did not always recognize the fob (necessitating alternating between both fobs), intelligent touch on door handles stopped working, the illuminated keyless entry touch pad on the b-pillar wouldn't allow locking/unlocking and eventually stopped lighting up, the Homelink on the visor only worked when right up against the garage door. The puzzling thing was that the Auto-Stop-Start continued to work even though it represented the heaviest draw on the battery. Prior to calling the dealer, I put battery on a trickle charger overnight and all features worked again; but only for the next day and then back to almost nothing again.
After relating all the above information and dealing with two service advisors (good cop/ bad cop) and the service manager, a replacement battery was finally authorized and installed. As suspected, EVERYTHING returned to 'normal" operation again . Something as common as a failing AGM battery on these overly-complex vehicles is a known issue, yet it is like pulling teeth to get satisfaction. It is my wife's car so I let her vent on them. We're hoping to get a followup survey from Lincoln--not to complain about the dealership, but Lincoln's warranty policies...assuming anyone actually reads them.
Hi Going_Going_Gone. With the information you provided, the issue here was not Lincoln's warranty policy, it was with the Dealership/Service Advisor/Service Manager.
Assuming a vehicle is still within the 4 year/50,000 mile New Vehicle Warranty the warranty coverage is simple: According to warranty procedure, all the Service Department needed to do was load test the battery. If it fails, it is automatically replaced under warranty. Keep in mind the Dealership may also want to perform some other diagnostics to be sure it is only a battery issue, but those procedures are also covered under warranty.
While a bit of detail may be missing as to exactly what happened and when (i.e. Were the conversations initially only over the phone? Or was your vehicle in their possession and they refusing to check the battery...etc. etc? All the Dealership needed to do was load test the battery. Also, we need to keep in mind that a proper load test takes several hours to complete, and they can not replace the battery under warranty without load test results.
So again, the warranty policies are simple and straightforward. Load test the battery and replace it if it fails. Therefore, at least with the information provided so far, the issues you had seem to have been with the Service Department, not Lincoln warranty policies.
