G
G-55958
Is there any mod available for the 2023 to install the mini console once the “full console” has been removed?
The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
If I recall correctly, the mini console is held to the bracket with clips. It pulls straight up off the bracket, the bracket is held in with 4 bolts. The front 2 are fairly easy to access, the rear 2 are under the carpet at the back. Removal of the middle captain's chairs is required to complete the swap. Hope this helps, good luck.Hoping to bring this thread back up since I just was able to obtain a full console...Yay Looking at the new, full, console, it looks relatively easy to put in.
Now, what I thought was the easy part, I'm now a little stumped. How do you get the mini one out?
I took all of the rubber pieces out of the mini (red arrows) thinking I'd see some screws/bolts but nothing. Before I start prying, I was wondering how @Moondog66 or @capajamas72 was able to get it out? Did you put like a thin screwdriver and pry the cupholder out between the plastic and the chrome?
Awesome Moondog. I'll give it a go.If I recall correctly, the mini console is held to the bracket with clips. It pulls straight up off the bracket, the bracket is held in with 4 bolts. The front 2 are fairly easy to access, the rear 2 are under the carpet at the back. Removal of the middle captain's chairs is required to complete the swap. Hope this helps, good luck.
When I got my console, I didn't get the bracket, side trays, and wiring harness. If you didn't get that you'll need at least the bracket and wiring harness to complete the swap. The side trays cover the bolts for the console.Awesome Moondog. I'll give it a go.
Much appreciated
That part I'm good with. I was able to find one with brackets and the wiring. (And the correct trim) I did find a couple but they were not the correct trim. Once you start looking at adding the correct trim, prices do add up.When I got my console, I didn't get the bracket, side trays, and wiring harness. If you didn't get that you'll need at least the bracket and wiring harness to complete the swap. The side trays cover the bolts for the console.
My 2022 grand touring has same low ctr console. I like it that way because we can fit something long in trunk w/3rd row seat down & it fits all the way up to front ctr console w/o sitting on or scratching 2nd row ctr console.FYI, my 2020 has the low step-over console. I guess it's useful for getting to the 3rd row, especially if you have children. I don't have the 2022 Lincoln Order Guide yet so I am not able to check that out. On the 2022 Explorer, the 2nd-row console shows as a Deleted item.
Welcome to the Forum.Has anyone converted the full size console to a mini console in a recent year Aviator? I'm thinking of buying one with the big console with the plan to downsize to the smaller one. Would like to know if anyone has the process and parts numbers to do it. Also, is there big holes left in the carpet?
I'm happy to do it. I'm retired and have the time to help out where I can. When I joined the Ford Explorer Forum back in 2010, I didn't know much about navigating these forums, so any assistance was welcome. A fee would only serve to put me in a higher tax bracket.Peter - you're evolving to everyone's search assistant on this forum. Perhaps you should get a fee for such services!
were you able to do this? I have the big console and would like to change it for the little oneI have a 2020 Reserve 1 with the small cupholder console. Does anyone know the part number of the full size console? Would like to retrofit it if possible.
Thanks!
I have a 2020 reserve 1 with full big console and I would like to change to the small oneUpdate on the console retrofit. Finally had time to work on it. Sourced a complete console from eBay, I had to order the mounting bracket from local dealer along with side trays. I was told the wire harness "should be there, but some aren't"...mine didn't so I ordered that too. Total parts ordered are:
Mounting bracket - LC5Z-7804-5B34-A (direct bolt in where the cupholder bracket or bench seat is located)
2 side trays - LC5Z-78045N28-AK and AD (left and right)
Mounting bolts (4) - W711158-S439
Wire Harness - N1MZ-14A699-B
Installation is fairly straightforward, unbolt seats and tilt forward (no need to unplug or remove). Unbolt front bolts on cupholder bracket, rear bolts accessible under carpet. Have to do it by feel, but no issue. Swap brackets, new mounting surface is slightly longer so carpet had to be trimmed a couple inches to fit. Plug for wire harness is located under carpet in front of 2nd row left seat. Plug cable in and feed under carpet to center bracket and plug into console. Bolt console down and side trays snap right in. Reinstall seats and bingo. Total time was less than 3 hours. I suck at taking progress photos but I attached one of cupholder bracket and finished job.
did you do this? I want to go from the big one to a small oneDo you know if the mini console would cover whatever is underneath the large console? I haven’t seen anyone go from a large to step over yet.
were you able to do this? I want to do this exact same thing, 2020 aviator Reserve 1, can you tell me what you did and what you bought and how to do it?Has anyone converted the full size console to a mini console in a recent year Aviator? I'm thinking of buying one with the big console with the plan to downsize to the smaller one. Would like to know if anyone has the process and parts numbers to do it. Also, is there big holes left in the carpet?
Welcome to the Forum.were you able to do this? I have the big console and would like to change it for the little one
I swapped out my mini console for the larger one in my Aviator. The large one included ambient lighting, charger ports and a sunshade switch. The harness for that was under driver seat and covered with a protective plug cap. The open circuit was dormant until I plugged in the large console. I wouldn't think unplugging it would cause any issues other than not being functional, but good idea to check with dealer tech.
Would you be able to elaborate a little as to where the harness is? Is it under the carpet, under the driver seat, or simply tucked under the bottom of the seat? I just don’t want to tear into anymore than I have to.I swapped out my mini console for the larger one in my Aviator. The large one included ambient lighting, charger ports and a sunshade switch. The harness for that was under driver seat and covered with a protective plug cap. The open circuit was dormant until I plugged in the large console. I wouldn't think unplugging it would cause any issues other than not being functional, but good idea to check with dealer tech.
Welcome to the Forum.Would you be able to elaborate a little as to where the harness is? Is it under the carpet, under the driver seat, or simply tucked under the bottom of the seat? I just don’t want to tear into anymore than I have to.
