G
G-220581
You're welcome! I'm going to sell the mini console and mounting bracket base.
Do you know if the mini console would cover whatever is underneath the large console? I haven’t seen anyone go from a large to step over yet.
The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
The 2nd row floor console was deleted on the 2022 Explorer.Also curious, I wonder if something from an Explorer would work.
So 2020 and 2021 could have them? got to be some in junkyards by now.The 2nd row floor console was deleted on the 2022 Explorer.
I'd love to purchase that low console if it's still available!DM'd
We have a 2023 Navigator w/ a full rear console. We’d love to remove it since we have a 3rd kid on the way, and having captains chairs w/ no console would make it much easier to access the 3rd row.I'll tell you how to remove it and you can decide if how hard it would be for you. It has side trays on each side that clip onto the console. They just pull straight out and you can access the bolts, 2 per side. Remove the bolts and the console lifts off the base enough to unplug the harness. Once removed, the plastic base and the harness will be exposed. It opens up the middle to access 3rd row, but passengers would be stepping over the base and wire harness.![]()
1 - yes, (for a fee)We have a 2023 Navigator w/ a full rear console. We’d love to remove it since we have a 3rd kid on the way, and having captains chairs w/ no console would make it much easier to access the 3rd row.
A couple of questions:
1) Would a Lincoln Dealer remove the console?
2) Would there be an east way to cover the plastic base/harness with a mat or something that would make it safe/elegant/functional?
3) would any functionality of the vehicle be impacted if you remove the console?
Thanks!
Welcome to the Forum.We have a 2023 Navigator w/ a full rear console. We’d love to remove it since we have a 3rd kid on the way, and having captains chairs w/ no console would make it much easier to access the 3rd row.
Thanks!
Sorry, ignore my reply, you mentioned Navigator, I assume you were Aviator (this is the Aviator Thread).We have a 2023 Navigator w/ a full rear console. We’d love to remove it since we have a 3rd kid on the way, and having captains chairs w/ no console would make it much easier to access the 3rd row.
Thanks!
I agree. There should be a trim panel on each side that covers the mounting bolts. Those typically have slide clips, once bolts are removed, it should lift off the bracket exposing the harness plug. If removing the mounting bracket, there is a bolt on each corner under the carpet. Removing the seat might be required to squeeze a hand and wrench in there (I had to do this on my Aviator console removal). It's pretty straightforward. Like 7.62Kolectr said, there will be a hole left in carpet.Most dealers will not remove a console from any car. Too much liability in it with the way lawyers are nowadays. The owner can do it fairly easily. There will be wiring harness’ and a hole in carpet left over. Yes this can easily be covered with a same colored floor mat.
You will lose some features but I do not believe it will affect reliability or function of vehicle overall.
Thanks for the excellent information. For those that can't find a used one, I am attaching the entire list of parts you will need to make the conversion from partial to FULL console. One issue I am having is the semi-exposure of the mounting bracket showing from the carpet cut-out. It seems the side trays do not fully cover the carpet like the mini-console does on my 2022 Aviator. Below is the entire list of parts I purchased to make this all work.Update on the console retrofit. Finally had time to work on it. Sourced a complete console from eBay, I had to order the mounting bracket from local dealer along with side trays. I was told the wire harness "should be there, but some aren't"...mine didn't so I ordered that too. Total parts ordered are:
Mounting bracket - LC5Z-7804-5B34-A (direct bolt in where the cupholder bracket or bench seat is located)
2 side trays - LC5Z-78045N28-AK and AD (left and right)
Mounting bolts (4) - W711158-S439
Wire Harness - N1MZ-14A699-B
Installation is fairly straightforward, unbolt seats and tilt forward (no need to unplug or remove). Unbolt front bolts on cupholder bracket, rear bolts accessible under carpet. Have to do it by feel, but no issue. Swap brackets, new mounting surface is slightly longer so carpet had to be trimmed a couple inches to fit. Plug for wire harness is located under carpet in front of 2nd row left seat. Plug cable in and feed under carpet to center bracket and plug into console. Bolt console down and side trays snap right in. Reinstall seats and bingo. Total time was less than 3 hours. I suck at taking progress photos but I attached one of cupholder bracket and finished job.
| Item | Trim-Color-Matched | Part # | Quantity | Amount |
| Box Assembly Stowage | Yes | lc5z78045a36al | 1 | $492.68 |
| Panel Assembly Console | Yes | lc5z78045a76ec | 1 | $254.00 |
| Panel Assembly Console | Yes | lc5z78045a76ca | 1 | $182.45 |
| Center Console - Rear, Center | No | LC5Z78045A36AK | 1 | $155.75 |
| Bracket Console | No | lc5z78045b34a | 1 | $153.55 |
| Panel Console | Yes | lc5z7804608bd | 1 | $139.27 |
| Holder Cup | No | LC5Z7813562AA | 1 | $120.43 |
| Panel Console | Yes | lc5z7804567ak | 1 | $92.87 |
| Panel Console | Yes | lc5z7804567ad | 1 | $92.36 |
| Panel Console | Yes | lc5z7804567an | 1 | $68.48 |
| Panel Assembly Console | Yes | lc5z78045e24ak | 1 | $63.85 |
| SunShade Switch | No | JL7Z13D730BA | 1 | $43.52 |
| Side Pocket Console | Yes | lc5z78045n28ad | 1 | $41.07 |
| Side Pocket Console | Yes | lc5z78045n28ak | 1 | $41.00 |
| Panel Console | Yes | lc5z78045e24dd | 1 | $37.08 |
| Cup | No | lc5z78045c22ba | 1 | $29.79 |
| Wire. 2nd Row | No | N1MZ14A699B | 1 | $22.85 |
| HS3 Screw | No | W505286S439 | 1 | $13.50 |
| Front Trim Mat | No | lc5z78045g34da | 1 | $13.26 |
| Cup Holder Mat | No | LC5Z5413562AA | 1 | $11.37 |
| Mount Bracket Bolt | No | w719498s451 | 4 | $11.00 |
| Clip | No | W719592S300 | 1 | $9.90 |
| HN2 - Nut | No | W717086S439 | 1 | $9.90 |
| HS1 Screw | No | W506943S424 | 1 | $9.90 |
| HS2 Screw | No | W718102S451 | 1 | $9.90 |
| Seat Belt Assembly Screw | No | w505286s439 | 4 | $8.28 |
$2,128.01 |
Wow, you don't realize how many parts are involved until you see an itemized list. I got lucky and found the complete console on ebay with the exception of the side trays, wiring harness and mounting bracket. I trimmed carpet under rear of console to use on front corners, you can barely tell it unless you're looking for it. Good luck on completing the install, it will look great when it's finished.Thanks for the excellent information. For those that can't find a used one, I am attaching the entire list of parts you will need to make the conversion from partial to FULL console. One issue I am having is the semi-exposure of the mounting bracket showing from the carpet cut-out. It seems the side trays do not fully cover the carpet like the mini-console does on my 2022 Aviator. Below is the entire list of parts I purchased to make this all work.
Some parts have to be color matched to your trim. I added a column stating whether color-matching is required or not.
Item Trim-Color-Matched Part # Quantity Amount Box Assembly Stowage Yes lc5z78045a36al 1 $492.68Panel Assembly Console Yes lc5z78045a76ec 1 $254.00Panel Assembly Console Yes lc5z78045a76ca 1 $182.45Center Console - Rear, Center No LC5Z78045A36AK 1 $155.75Bracket Console No lc5z78045b34a 1 $153.55Panel Console Yes lc5z7804608bd 1 $139.27Holder Cup No LC5Z7813562AA 1 $120.43Panel Console Yes lc5z7804567ak 1 $92.87Panel Console Yes lc5z7804567ad 1 $92.36Panel Console Yes lc5z7804567an 1 $68.48Panel Assembly Console Yes lc5z78045e24ak 1 $63.85SunShade Switch No JL7Z13D730BA 1 $43.52Side Pocket Console Yes lc5z78045n28ad 1 $41.07Side Pocket Console Yes lc5z78045n28ak 1 $41.00Panel Console Yes lc5z78045e24dd 1 $37.08Cup No lc5z78045c22ba 1 $29.79Wire. 2nd Row No N1MZ14A699B 1 $22.85HS3 Screw No W505286S439 1 $13.50Front Trim Mat No lc5z78045g34da 1 $13.26Cup Holder Mat No LC5Z5413562AA 1 $11.37Mount Bracket Bolt No w719498s451 4 $11.00Clip No W719592S300 1 $9.90HN2 - Nut No W717086S439 1 $9.90HS1 Screw No W506943S424 1 $9.90HS2 Screw No W718102S451 1 $9.90Seat Belt Assembly Screw No w505286s439 4 $8.28 $2,128.01
Ford Parts is the most expensive place to buy parts. I'm sure the total would be quite a bit less from Levittown Ford. Genuine Ford Parts Dealer Online | Levittown Ford PartsI sourced all the part numbers from
Part numbers found here - https://parts.ford.com/
Purchased from - Genuine OEM Ford Parts and Accessories | FordPartsOnSale.com
Another inexpensive place to buy parts - Factory OEM Auto Parts & Accessories | TascaParts.com
Agreed Peter. Buying directly from FORDPARTS.com vs Levittown Ford or another dealer would have cost at least another $600-$800 more. The ONLY benefit I see with sourcing the correct part numbers from FORDPARTS.com vs someone else is this example I will provide.Ford Parts is the most expensive place to buy parts. I'm sure the total would be quite a bit less from Levittown Ford. Genuine Ford Parts Dealer Online | Levittown Ford Parts
I'm not sure either, but Tasca also states it does not fit a 2022 Aviator Reserve.Agreed Peter. Buying directly from FORDPARTS.com vs Levittown Ford or another dealer would have cost at least another $600-$800 more. The ONLY benefit I see with sourcing the correct part numbers from FORDPARTS.com vs someone else is this example I will provide.
This part number (JL7Z13D730BA) is to the FULL rear console ShadeSwitch - for the 2020-2024 Lincoln Aviator
FORDPARTS.com Fitment says: This part fits your 2022 Lincoln Aviator
Levittownfordparts.com Fitment says: This part does not fit your 2022 Lincoln Aviator
- Lincoln Navigator 2018 - 2024
- Lincoln Aviator 2020 - 2024
I have no idea why one source is different that the other.
- Lincoln Navigator 2018 - 2023
Thanks
