So I got a great deal on a lightly driven low mileage 07 Town Car from an 89 y.o, has suffered the infamous leak problem (as well as the gurgling noises behind the dashboard problem)-- water ended up pooling in the rear.
Having never owned a Lincoln, Initially I thought it was a heater core problem given the gurgling behind the dashboard but I don't lose coolant and the liquid that ended up in my wet / dry vac is obviously water.
So I did the usual silicone seal around the vent under the hood (found that the gasket was of course completely dry rotted into oblivion)...but while doing it, I noticed this (see pic)...could this gap at the seal at the bottom of the windshield be causing a leak as well ?
Or is that normal?
On another note, this is just completely ridiculous! Over the last 6 years I've owned multiple Japanese vehicles and have never had to worry about a water leak in a car until I owned a Lincoln
Thank you
