MSFT Sync 4.4 download file
Glad to hear and be of help.
FWIW, 4.6 works well for me, but I don't use Siri for commands.
I too need the 4.4, if you don't mind. Would you still mind sharing it
I concur, 4.6 works for everything else, but it does not work with Siri. You cannot activate siri or do voice-commands for text input, etc. Only 4.6 has this issue, all past upgrades have worked fine.
Skydiver,
If you're John, I've uploaded it to Dropbox.
If not, I'd need a Dropbox invite or an eMail address for WeTransfer.
That won't work. It's not linked to you, nor can I upload to it.
Sorry, not sure what happened. It is linked to me.
Maybe just send a WeTransfer link to skye_diver@hotmail.com
It looks like the only way I can give edit/add permissions in Dropbox is to email a link to someone directly from within Dropbox.
Thank you.
It's on it's way via WeTransfer. You will get an eMail with link.
Hi SGilbert... I'm new to the forum but was digging for some info and came across these posts. I have a 2012 MKX which I was looking for an update for the sync which I never found.. Did a chat with one of the Lincoln sites and was told the version 3.6 was no longer available for download (mine is on 2.something and the last update was never) and that the only way to get it would be to go to the dealer.. I assume I have the sync that does it all from the research I've done. Any way to get the file without going to the dealer? Thanks ahead big time...
I have DR3T-14D544-AG and Gen1v441buildEE2824updatefromv3263packageRev2.
The former is before the latter.
I have no idea whether either will work for you on a '12 MKX.
They're yours if you choose, but you're on your own if they brick your system.
Will need your email address.
I was told by Lincoln I need the version 3.6 willistanner@gmail.com
Just seems really odd they pulled the updates and no plan to put them back in the near future...
Then I suggest you visit your dealer. You MAY be surprised if they don't charge you. Some don't. Suggest you combine the visit with something they can 'make a buck' on.
Same as I was thinking... Thanks again...
Is it possible to get a copy of Ford Sync 4.4. 4.6 disabled siri integration
I have a 2012 Ford explorer with sync gen 1. I updated to 4.6 and siri integration is now disabled. Is it possible to get a 4.4 version?
Post your eMail address here and I'll forward it to you through WeTransfer.
You can delete the address after you get the file if you wish.
SGilbert,
I am also looking for the coveted sync v4.4 files. I have upgraded and miss the Siri functionality. Please send the wetransfer link to kplee23@hotmail-dotcom. Thank you!
