angore
- Apr 3, 2024
- Location
- Triangle area. North Carolina
- 2024 Nautilus Premier Hybrid (Sheila)
Interesting....Did you have the Nautilus attached to home wifi?
The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
I'm pretty sure ours updated at home on WiFi, but I can't be 100%. Btw, the update details says the change has no visible effect.Ours did today as well. Only seems to do these OTA updates while away from our home network.... not sure but everyone that has applied has always been while not at home. Curious to see any differences or enhancements with this one![]()
FYI, the split screen you describe has been our default home screen forever.I’m not sure what update I got a couple of days a go but I now have an option for a split screen on the center display where it has a small map on the left, what entertainment is playing on the lower right and a search bar at the top on the right. It seems this is activated by a small box in the lower left of the screen. I use CarPlay and Waze as my center display map so it is nice to have the split screen since Waze doesn’t display well on the large up front display. Also, an update I got added the compass as a widget. My wife prefers the other widgets so only use it when I’m alone. Does anyone think there may be more widgets coming?
I too have been wondering what I loose when connectivity goes away, however, it seems to keep being extended every time I look. It is now due to expire at the end of January. We bought the 24 Nautilus Rev II in April of 24 so we are now 1yr and 9 m0nths into connectivity.
I have had mine since Feb 2024 and had the 1 extension that brought it to 11/30/25 expiration date.FYI, the split screen you describe has been our default home screen forever.
Has anyone else with an early '24 purchase seen this extension? I'm Match '24, and I haven't seen it. Any other '24s after April?
I purchased in July 2024 and was notified my subscription would expire Nov 30th. As of 1:22 PM Dec 1 I still have full functionalityI have had mine since Feb 2024 and had the 1 extension that brought it to 11/30/25 expiration date.
Mine was expired when I started my car this morning.I purchased in July 2024 and was notified my subscription would expire Nov 30th. As of 1:22 PM Dec 1 I still have full functionality
What did you lose?Mine was expired when I started my car this morning.
I’ve noticed a few things:What did you lose?
If you just got the compass, you should also have got an alternative type of clock and an alternative type of weather widgets. These are settings on the widget when selecting them to the screen.I’m not sure what update I got a couple of days a go but I now have an option for a split screen on the center display where it has a small map on the left, what entertainment is playing on the lower right and a search bar at the top on the right. It seems this is activated by a small box in the lower left of the screen. I use CarPlay and Waze as my center display map so it is nice to have the split screen since Waze doesn’t display well on the large up front display. Also, an update I got added the compass as a widget. My wife prefers the other widgets so only use it when I’m alone. Does anyone think there may be more widgets coming?
This is consistent with what I see. I had added a My Radar app and it no longer works and cannot even remove it. There is a link to re-activate using a QR code and provides an option to turn off upper map. If you use a phone, the map will still appear on both but looks different (has gradient border and not always in dark mode). Widgets all work.I’ve noticed a few things:
1. Native Google Navigation will only work within the geographic area where your car already has downloaded maps. For example, when I tried to navigate locally, it worked. But when I tried to navigate somewhere I have never driven to it will not work.
2. Within the navigation that still works, the real-time data like current traffic does not load.
3. I was still able to use Google Voice Assistant to control my car’s temperature.
4. Google can no longer tell me the local weather verbally.
5. The Google Play store is no longer online. It won't load apps that are available to be downloaded. It still seems to have the existing apps that were installed. But it can't update them.
6. There is a brief "can't connect" message displayed now and then... like when you load Google Maps.
7. There is now an "A connectivity package available" message permanently displayed on the lower left of the Home Screen.
8. Right now, the upper map screen still displays Google Maps of my local area. But I suspect that if I were to drive out of the local area, when it no longer has maps downloaded, it might display a blank area in the map display. Or perhaps an error message. Not sure I will like that.
I hadn't seen the option to turn off the upper map yet. I'll look for it. Have you done that? If so, does it just leave empty dark space where it was?This is consistent with what I see. I had added a My Radar app and it no longer works and cannot even remove it. There is a link to re-activate using a QR code and provides an option to turn off upper map. If you use a phone, the map will still appear on both but looks different (has gradient border and not always in dark mode). Widgets all work.
Since I use Android Auto, when I navigate it shows up on booth screens.I hadn't seen the option to turn off the upper map yet. I'll look for it. Have you done that? If so, does it just leave empty dark space where it was?
