Update 11 Center Touch Screen
Sweet - we got the Center Touch Screen APIM update at midnight (could see the SOC drop when it installed),
I ran the multiple volume presses evolution to force a system restart. After that I went through several car start/stop cycles to check the changes, including persistence of things:
-New widgets are there, as reported.
-Navigation prompt volume changes persist, at least within a given drive cycle (I ran a lot of "hey Google, navigate to..." rounds, adjusting volume, to see that the new volume setting was used on the following responses)
-Bonus! car-usb-handler appears to have been added (or fixed). AudioWagon retains access to the USB across restarts. @Sharbotcom
(AudioWagon is a USB media manager app available from the car's Play Store. It lets you use commands like "hey Google play artist Fleetwood Mac album Rumours" if you're already listening to AudioWagon/USB, or "hey Google play Wake of the Fluid on USB" if you're presently listening to SiriusXM.)
I had the update installed at the dealer and it still doesn't hold the permissions for AudioWagon.
I'm back at the dealer on Monday for testing with the engineers. Let me know if anything changes with regards to persistent permissions on your vehicle this weekend. Thanks.
I will. Since the OTA it's been very consistent, working across multiple restarts testing things.
This is what went in at midnight. Prior to this APIM flash AudioWagon was 100% consistent in needing to have USB access (the checkbox thing) thanks on every restart.
Note: if you did have this update, it's always possible it was a bad flash, sometimes that happens without any obvious issue.
This is what went in at midnight. Prior to this APIM fish AudioWagon was 100% consistent in needing to have USB access (the checkbox thing) thanks on every restart.
Mine shows the same update release id but still no sticky permissions for AudioWagon. Thanks.
I tested it today and appeared to stick. Was the checkbook there before?
The checkbook i see is much smaller.
You should only have seen it once to set it and never again if it working right.
I no longer get the AudioWagon USB access pop-up on starting the vehicle. I'll check again tomorrow.
