Hugo Drivenow
- Apr 7, 2024
- 2024 Nautilus
Dan-NJ, Thanks for the update! Glad to see you got some resolution!
Sorry, I don't have any documentation so share....but.... I was sitting in the parking lot yesterday and noticed that while our Hybrid was "Ready" / running without the ICE, I opened the BM300 Pro app on my iPhone and the 12V battery showed "Charging" and both the SOC and Volt levels were increasing slowly! So, it appears to me that the system is charing the 12V battery using power from the Hybrid battery. Again, my observations only and hopefully this is also documented somewhere in a Nautilus manual.I thought I had found information that stated the 2024 Nautilus Hybrid used the high voltage battery to charge the 12v battery. Can anyone confirm if this is accurate? If you have a link to this information I would appreciate it to learn more. Thanks,
The high voltage battery also starts the ICE via one of the transaxle motor generatorsSorry, I don't have any documentation so share....but.... I was sitting in the parking lot yesterday and noticed that while our Hybrid was "Ready" / running without the ICE, I opened the BM300 Pro app on my iPhone and the 12V battery showed "Charging" and both the SOC and Volt levels were increasing slowly! So, it appears to me that the system is charing the 12V battery using power from the Hybrid battery. Again, my observations only and hopefully this is also documented somewhere in a Nautilus manual.
Hope this helps Cypressmyrtle![]()
Yes, that is one duty the 12V battery does not have compared to the gas only model. I like the fact the hybrid is instant on and ready to go. I have read that the charging system in some hybrids is nothing more than trickle charger but have not seen anything confirm sophistication. The other question is the charging rate adjustable by drive mode such as does conserve reduce charging rate?The high voltage battery also starts the ICE via one of the transaxle motor generators
Thanks, I wish I could find where I read this information.Sorry, I don't have any documentation so share....but.... I was sitting in the parking lot yesterday and noticed that while our Hybrid was "Ready" / running without the ICE, I opened the BM300 Pro app on my iPhone and the 12V battery showed "Charging" and both the SOC and Volt levels were increasing slowly! So, it appears to me that the system is charing the 12V battery using power from the Hybrid battery. Again, my observations only and hopefully this is also documented somewhere in a Nautilus manual.
Personally I would get my dealer to check that battery before taking it on that trip.In the last 3 days my 2024 Nautilus Hybrid JUST started going into sleep mode for no apparent reason. Cant remote start. Infotainment takes about 1 minute to boot up.
Now here is the question.
Given the time of year this couldnt happen at a worse time. I am supposed to go to the Mountain for 5 days. Its about a 5 hour drive.
Is there a material risk that the car will go kerflooy? I really want to wait till after Chridtmas to take the car in.
I agree about taking it in, but at a minimum, have a good multi-cycle jumper.In the last 3 days my 2024 Nautilus Hybrid JUST started going into sleep mode for no apparent reason. Cant remote start. Infotainment takes about 1 minute to boot up.
Funny thing about that… It's our first hybrid, and the first morning after taking it home my wife and son were taking it out. She comes in and says she's tried to start the the car a half-dozen times and nothing happens (except the easy-entry was sliding her back and forth). "Are you pressing the brake?" "Of course!", she says like I'm trying to embarrass her. We go out there, she's shows me. "See? Nothing." "Ummm, you know this is a hybrid, right?" After that, we discover the READY light and she's on her way.I like the fact the hybrid is instant on and ready to go.
AGM batteries are compromised when shut down in a partial state of charge. Sulfation creeps in in at this point. The best care for longevity is to have the battery at full state of charge at rest after a cycle.Are initial batteries on Nautilus faulty possibly due to long transport? I couldn't find the battery recall that the early poster mentioned, only the recall for window. The paperweight is being towed to dealer....Thinking if they replace battery maybe do trickle charge nightly to top it off to help avoid travel issues? Obviously open to ideas.
So are you thinking that normal transpac shipping can be fatal to our batteries? How do the Japanese and Koreans do it?To answer your question, yes....the long transport time and short cycling times of the battery during transport does not allow the battery to reach full state of charge, so sulfation starts to set in.
My Genesis GV70 had the battery replaced after 8 months. It developed high internal resistance. That's how the Koreans do it, I guess.So are you thinking that normal transpac shipping can be fatal to our batteries? How do the Japanese and Koreans do it?
A smart charger will indeed help keep the battery up to snuff between cycles!
I always charge up a new battery before applying its first load (cycle) on it to get as close to full state of charge as possible. New batteries sitting on the shelf will partly discharge over time even with no load applied. I always bring a voltmeter & select the highest voltage reading battery with the most recent manufacture date code.
The only AGM battery currently in my household is in my 2023 Nautilus. I use a NOCO Dual bank charger (2x2) to keep all my vehicle batteries up to snuff. Charging Bank #1 I have set to AGM for my Nautilus, and I set Bank 2 for all my other conventional Lead Acid battery vehicles.
