swindler
- Sep 11, 2023
- 2024 Nautilus R2H
The tender cannot determine if the 'full charge' is equal to the 'brand new' charge capability of the battery. As you said, only that the full voltage was reached. Like your 5 year-old phone, it will charge to 100%, but still only half it's initial charge, or perhaps even less. Time to charge isn't really a factor, as the battery's internal resistance will be higher, causing is to charge slower.My Delran Battery Tender takes 12-18 hours to bring the Nautilus up to a full charge. It only goes to green when peak voltage is detected and then it goes into the trickle mode.
When used regularly on my Mustang I got a full 10 years out of an Optima Red top battery! The only reason I had to replace it was the neg battery post corroded off…lol.
We had one battery death, with the vehicle sending a DSM only 90 minutes after being driven. Although it seemed fine for about a month after being jumped, when we finally brought it in and had it tested the battery failed. I think you should have it tested after every event. I have a CCA tester which provides a fairly accurate indication of it's charge capacity.
