Customer Satisfaction Program 24B54 - Certain 2024 Model Year Nautilus - Update Infotainment Software
Having read about the issue with the mirrors not folding on lock, I asked the service advisor to stay with me as I tested it. Sure enough, when I locked the vehicle, the mirrors did not fold.
But here's the good news! We got back into the car and checked the setting. Sure enough, it showed that it was set to on.
So I turned it off, then back on, and we got out and tested it again. And voila! It works now. So the issue is that that software update causes the display of the setting to be out of sync initially with the actual setting. I asked him to please report it to Lincoln.
Well, almost three weeks after 24B54 install, my auto-fold mirrors suddenly began working. Very happy.
Now, if only I could get my weather app to update. It's stuck on the weather from more than three weeks ago.
How many times have you rebooted since the update?
Many. While driving. While sitting in my garage connected to my home wifi. I've disconnected and reconnected the battery. What else?? fwiw, the weather app froze a few days before the update. I had hoped the update would fix it.
I took mine in today for the update and service rep texted it was done. They do video where mech explained what was updated. I also picked up a cabin filter, air filter, and wipers for 20% off. No installation. I am also getting tires rotated. I am getting lazy since I used to rotate myself since I have a floor jack and stands
Today I noticed that every time I start the car, the radio comes on. I turned it off multiple times today and at every restart, the radio was back on. In my case, it is SiriusXM that comes on. Anyone else experience this? Is this a byproduct of the update? I don’t remember this behavior before, but it could be that I never noticed because I usually have the radio on.
Mine has always done that. I was hoping 24B54 would change that behavior, but it didn't.
I've played with turning off the radio while on an AM or FM station before turning off the car, but it makes no difference, the radio still turns on when starting the car.
I haven't found a "fix," but the radio doesn't turn on automatically for some other owners in this thread, and it didn't on a 2024 loaner I had a few weeks ago.
My mirrors suddenly stopped folding a couple weeks after the update :(.
If I toggle the setting then they will fold one time, but not unfold until I press the button.
Yep, that was exactly my situation after the update. Unit it wasn't.
That’s messed up. I wonder what’s special about our cars?
I had the same hope. Both of my earlier Nautilus' and my Corsair had the same behavior. Thankfully, I only rarely turn the radio off. Mostly keep it turned down when I'm not interested.
I am somewhat surprised this update was not put on hold.
If picked up my Nauti after the 24B54 update.
My notes
- mirrors did not auto fold until I toggled setting off then back on
- had to redo permissions on location and send location Lincoln
- Nice to hear touch click when adjusting temp and drive mode
-48 in display seems a little dimmer at max brightness
- Did not notice prompt muting sirius
- brake coach seems to work better
- saw coolant toggle and turned it back on
- display seemed faster
- when I first started the city weather tempswas way off. On next restart the right side was briefly blank and weather was fixed
- Dealer did the usual inspection on tread depth, brake pad thickness, and tested battery, etc.
Reboot seems different. After initiating left side comes up immediately then see loading profile message on small display and right side and small display come up. There is a strobing line on the small display that stops when everything is up. The phone connection was last step. It takes longer overall to get all up but seem more orderly.
I just had the CSP 24B54 update on my 2024 Nautilus completed at the dealership.
Has anybody else experienced the sound of the turn signal having an intermittent hiccup? A pause every few seconds, not steady?
It doesn't impact the operation of the turn signal lights. Just the clicking sound.
Several people have noted it's louder. Does it still have a regular cadence, or is it erratic?
I haven’t noticed that it is louder. Definitely erratic, skipping a beat. Used to be a regular cadence as you would expect. Not cyclic, either.
My turn signal seemed to work ok but sound did change as others reported earlier. It seems be "crisper" (short tone).
Have you done a reset (volume control held down for ~10 seconds)? Several others have noted this cleared up several funky things after that software update.
