If you know your VIN you can go here, and after accepting terms you'll get to a page where you can choose to plug in VIN. If you see CSP 24B23 injector replacement listed, then Ford/Lincoln have determined that yours is one of the vehicles that should get the fix.
(If you don't know your VIN yet, ask the dealer to check for if that CSP 24B23 is listed for your vehicle. If they say there's no way to check it, I would ask to speak to the dealer manager - they CAN check for that.)
Failures have been seen very early (within the first few hundred miles) and noticeably later (up in the 2300 - 2400 mile range). From what people posting here have provided, there's no obvious specific driver action that led to a failure.
If it were me, if the VIN is listed and I haven't taken possession I would hold off - tell them you want the fix installed prior to signing/key handover. Several people have done so recently, choosing to wait to get a car without the issue rather than start driving a vehicle that could have a major engine failure due to a known problem.
Supposedly the dealer bulletin and parts ordering process will be out very soon. Ask your dealer to spot your vehicle in as early as possible to have the repair done (rather than prioritize unsold vehicles on the lot.)
(First in line should be the vehicles that are actually in buyers' hands, already bring driven as they're essentially running at risk, but vehicles where there's a commitment, though handover hasn't yet happened, should also be high up in priority.)
