Update on the console retrofit. Finally had time to work on it. Sourced a complete console from eBay, I had to order the mounting bracket from local dealer along with side trays. I was told the wire harness "should be there, but some aren't"...mine didn't so I ordered that too. Total parts ordered are:
Mounting bracket - LC5Z-7804-5B34-A (direct bolt in where the cupholder bracket or bench seat is located)
2 side trays - LC5Z-78045N28-AK and AD (left and right)
Mounting bolts (4) - W711158-S439
Wire Harness - N1MZ-14A699-B
Installation is fairly straightforward, unbolt seats and tilt forward (no need to unplug or remove). Unbolt front bolts on cupholder bracket, rear bolts accessible under carpet. Have to do it by feel, but no issue. Swap brackets, new mounting surface is slightly longer so carpet had to be trimmed a couple inches to fit. Plug for wire harness is located under carpet in front of 2nd row left seat. Plug cable in and feed under carpet to center bracket and plug into console. Bolt console down and side trays snap right in. Reinstall seats and bingo. Total time was less than 3 hours. I suck at taking progress photos but I attached one of cupholder bracket and finished job.
