I checked continuity to C2089 (adjustable pedal switch) and C238 (connector down in the kick panel referenced above), both are good. The wires are dead, and possibly shorted, somewhere past C238. I jumpered from the junction box out to the seat controls on the door, but the seat still did not move. Guess which wire comes off of C238 and also goes under the carpet to the seat module? Yep, the LG/VT wire again. I bet the Ford engineer's name who came up with this was Sauron Jr. One Wire to Rule Them All. But I digress.
So what that tells me is that LG/VT dies somewhere just past C238, before the splice out to the seat, and
also, to the power trunk. Did I mention One Wire to Rule Them All?
Below is the power distribution diagram with my plans and notes to solve this. I'm going to cut LG/VT before C238 because that's the only place I can get to it. From there, I'll do a 1->2 wire split with GR going out to the door, an WH splitting again under the dash with RD to the pass side lock (hopefully I can find LG/VT going to the pass side lock switch under the dash on the driver's side to splice into) and WH down to the floor where it will split again into BL for the seat and Y for the trunk. This is the little diagram at the top under Note Wire Colors.
Everything in the door is noted by a sort of pink check mark. I can get them all with the one GR wire out to the door. I'll have to do 1 -> 2 -> 4 -> 7 wires the way Ford did it to keep the splices manageable. The 4->7 piece is already in place as you can see from my earlier pic. The other splits above take car of everything not in the door, which is outlined in yellow (Ignore the small yellow boxes around the C501 DDM connectors).
My guess is that this will take me the better part of a week to do in my spare time.
I'll let you know how it all worked out.....any constructive feedback on the plan is appreciated.
PS - does anyone know how to get that heavy black plastic conduit apart that runs under the carpet between the seat and the door? It would be nice to put my splices for the seat and trunk in there.
