SYNC 3.0 update available! 4/30/24
I believe I need an update to my Sync 3, but the Lincoln website says mine is already up to date. My Sync says it is Version 3.0 Build 17302_Product...
Hi whogg0521. What model and model year Lincoln are you driving? Have you ever successfully updated the SYNC 3 system (or the NAV maps) in the past?
There have been reported instances of some Lincoln vehicle models not being eligible for all the SYNC 3 updates. If I recall correctly, certain model year Navigators were one of those models.
If you feel there is a mistake, calling Lincoln Concierge would be the next step.
Why not update to 3.4 23188? I have a 2016 Ford Fusion and updated my (self-installed SYNC 3 unit from a 2019 F-150) from 3.0 to 3.4 and it looks worlds better and doesn't have any issues. Plus 2024 maps as well. Anywho, its free from Cyanlabs. Looks like the newest vehicles and has all the latest map updates too!
I just downloaded it today via WiFi and my Lincoln vehicle dashboard online shows it was updated.
Anyone have any luck getting the 4G kit? I just got the car and the Ford dealership had no idea what I was talking about and said it was impossible.
You can still update to v3.4 build 23188 which is the very latest version for free. Just need to go to Cyanlabs website. It downloads the official files from Fords Servers too. As far as the 4G connectivity kit goes, its just a TCU replacement. Dealerships will tell you alot of things that work to their advantage to get you into another vehicle.
The Sync update went without a hitch using a USB drive. Only took a couple of minutes.
I also updated my '18 MKZ maps to NA 2 24 today with no issues. This was my 4th map update, so I guess I'm learning the process ;)
It took about 40 minutes plus a half hour or so to download the files from the Lincoln site and prepare the USB stick.
Hi Jeffc. Just wondering what version of SYNC 3 is now showing in your vehicle SYNC settings?
Thanks and good luck.
So, after 2 months ownership, it's time for me to join this fray - with my SYNC 2.2.
Sitting on but not running, I never got past the spinny "Checking for updates", for probably an hour - presume until it timed itself off. What's supposed to happen? Neither site nor manual gives clue beyond updates will happen in background. Only clue is the last check for updates was in May, which was probably the dealer - sure wish they'd updated then.
Not sure I want to try leaving it running that long.
Thanks,
- Jeff
Thanks,
- Jeff
Hi batchman. What model year is your MKZ? And what is the full SYNC version currently installed in your vehicle?
I get the impression you are referring to WiFi updating? If yes, forget about WiFi updating. It is problematic at best, even in SYNC 3.4 equipped vehicles.
Instead, go to the Lincoln SYNC 3 update website and follow the instructions to check for available updates. If any are available, follow the instructions to download them to your computer, transfer them to a USB drive, and then install the updates in your MKZ.
If you are referring to trying to install a SYNC 3 update via USB flash drive: As per Lincoln , the engine must be running during SYNC 3.0/3.4 USB update installations.
I simply wait and perform the installation during an hour+ drive.
In the meantime, provide a bit more information and I’m sure one of us can help you.
forget about WiFi
Guess the fact there were 0 wifi success stories was not sufficient clue ;). I thought perhaps being able to park right outside my router would help.
And I have updated my descriptions to include the year, thanks for getting me to realize that omission.
Sigh, and thanks,
- Jeff
Sigh, and thanks,
- Jeff
Hi Jeff. You are very welcome.
Yes, WiFi updating of SYNC 3.0 was problematic from the very beginning. And while it improved very slightly with SYNC 3.4, it was still far from good. Essentially, it never met promises/expectations.
SYNC 4 corrected the issues and was far better. And the new Google based system is even better again.
In my case, when I first purchased my 2018 MKZ, I installed a WiFi booster at the closest point in my house to the driveway. While it offered a strong signal to the car, it still did not improve WiFi updating for SYNC.
Over the years, I did have two SYC updates actually begin via WiFi (out of about 6 total), but they were downloading so slowly, I still went to the Lincoln SYNC site and downloaded/installed them manually via USB flash drive.
On a related note, SYNC 3.0/3.4 updates are extremely rare nowadays, since they are legacy systems. Any updates are usually only to prepare the system for new NAV map updates (once a year), or an extremely rare bug fix. So once you make your initial check now, don’t go crazy checking every day/week/month etc. Once every six months will do. Plus, when an update does become available, someone will usually post a heads up here on the Lincoln Forums.
In your case, definitely go to the SYNC 3 update website and check for available downloads for your vehicle. Then, follow the instructions to download and install them.
The manual update process may seem confusing at first, but it is actually quite easy once you are familiar with it. There are also several existing threads explaining the entire process and how to avoid common mistakes. And obviously, just ask questions if you have any.
Let us know how you make out and good luck. 🍻
Well, it took me a while to actually get started, as with everything I do...
Downloaded the zip file, and found it to contain about 1.5gb of data. Not having any exfat sticks around, and only one in the 16-32gb range (that I don't want to scrub and re-format), I took a look at what's provided and see the 'meat' is 1.5gb of gzip files. IME gnu zip compresses about 50%, so I freed up an 8gb stick, re-formatted, and have it ready to go.
Reading further into the instructions they appear to want you to leave the car idling, in Park. Re-reading the thread, it sounds like folks have done the USB update while driving, which is good because I'm allergic to idling that long. Reading between the lines of the instructions plus above posts, I am guessing the Park requirement is just to get things started.
I have an hour ride coming up, which could conceivably stretch to 2 with a modest idle before returning. Question is, can you listen to radio or Sirius while updating? Is there a process, like set your station for the next hour before starting?
Thanks much,
- Jeff
Thanks much,
- Jeff
Hi Jeff. Yes, you can use the audio system, climate controls etc., while performing SYNC 3.0/3.4 updates.
No need to set the station, source etc., before starting.
Keep in mind there may be a SYNC reboot or two/three during the update, so you may briefly not be able to use them for a short period of time. However, the reboots are short.
Thanks for a very quick reply, BBF!
Best,
- Jeff
Whelp, about 20 minutes into my hour ride it reported the update was complete. I did have a moment where it didn't like the stick, but 2nd try did the trick. It did re-boot once maybe a third of the way through the process, can't recall if it did it at the end.
Since I was driving I did not turn the machine off and on again, and forgot to look when I got in next. Once I was home at the end of the day, I turned on auto-update with the stick in place and did get a confirmation message, took 3-5 minutes IIRC.
The only behavioral change I've noticed is welcome, my prior rant about silencing the GPS voice now shows an X when punched, even if it still talks to upon setting a destination it shuts up after that.
Thanks again for this forum and the info and contributors herein. Now to decide how much I care about maps... unlike a couple other "modern" cars, the '17 shows only the speed limit from GPS, and our local highway moved from 55 to 65, bet that won't show up just yet... At least it doesn't flash like our BMW.
Cheers,
- Jeff
