MSFT Sync 4.4 download file
bownz, will send you 4.4.1 & 4.6. I have no idea what 3.3.1c is. If you have other than '10, '11, or '12 Lincoln MKT. I take no responsibility!!
Prelzel, I can only forward you a link with an eMail address. Same warning as above!!
I have a Ford focus 2012 with a sync1 module. I believe it is the system.
Ah right, can you send it to this email
Thanks!
Sent to both of you. You can now, if you wish, delete your email addresses on this forum thread.
Trying to figure out how to do that. I don't see the option to delete or edit.
Guessing you need a minimum 15 posts or so to do that.
Interesting to note, the update file didn't work, however I switched to the Ford south African website where sync1 was still supported and supplied my VIN (https://www.ford.co.za/) and they emailed a link to the correct software.
I'm not sure if there is an equivalent Lincoln website to lookup your vin.
Hi SGilbert, can you please send me the both update 4.4.1 & 4.6 ??? Much appreciated... my email is bowoow@yahoo.com ... thx
Thank you very much for the file ... just wonder if you have the 4.6 version ? Also, what is the update procedure ... thx
I sent you 2 files: 4.4.1 and 4.6
Check Lincoln's Owner site. (I sold my MKT in Sept. 2021 and hadn't updated the Sync for MANY years before that as 4.6 was the last update.)
Hi, is this "DR3T-14D544-AG" 4.6 ?
No speak Espanol! I would need an email address!
Don't forget, my Sync files are for original Sync--not for subsequent 2, 3, & 4! Also, specifically for the '10. '11, & '12 Lincoln MKt, although it MAY work on other vehicles!
Can you also send me those two files? My email is sophist.bullock.0l@icloud.com
Thanks!
On their way. Check your eMail
