MSFT Sync 4.4 download file
I have the 4.4.1 update for my 2011 MKT Sync1 if you think it will work on your 2011 Navigator.
4.4.1 came after 4.4, but before 4.6 which is the newest you can get.
I also believe I have 4.6.
If you want either or both, I can send to you via WeTransfer which can handle very large files. I will need an eMail address to do so.
I would appreciate it. It's worth a shot.
Thank you
@bbf2530 and @SGilbert
Well I thought it was going to work. I started the install and soon after got the install complete message. Wait for 30-35 minutes like the directions said and got no other message. Continued to wait till about an hour and 20 minutes and nothing. Couldn't wait anymore so I shut off the vehicle then started again after 5 minutes but it's still on the same old version. 🤷‍♂️. Tried it again today and still the same thing. UGH frustrating.
@SGilbert
I've been doing some research and came across your post here that you had the to have the dealer update sync for you. Looking at it they updated it to v3.2.6. Which is the 4th update after my current version. My questions for you are:
Since that time have you had any issues with updating on your own?
How many times have you updated on your own?
What I'm trying to figure out is was there something in that update you received that was essential to have future updates work. The next step is seeing could be just finding a somewhere I can down load that update (BG1T-14D544-AJ).
@SGilbert
Firstly, I sold my MKT in August 2021. See my sig.
I have no recollection of ever having the dealer's service dept. doing an update. I always did my own by downloading from Lincoln to a thumb drive.
That update doesn't have a version #, so I have no idea what it is.
Somewhere on my external HD, I have version 4.6. If you wish to try that, I can send it to you. just like the 4.4.1.
Your troubles with 4.4.1 MAY have to do with you not havind an MKT, but, not being a geek, I can only guess!
Hi, I'm also a new owner of a 2011 Lincoln Navigator. I have tried many of files that were downloaded from across the internet without success. The system just showing the update failed all the time. Could you help to send me the files you have? Thank you so much.
I do, but need an email address to forward it to you.
I have the 4.4.1 update for 2011 MKT Sync1.
My question should have been, then, what year is your MKt, &/or, what version of Sync do you have. Mine is Gen 1, if you have Gen 2, which is MyLincolnTouch, My file will not work for you.
Edit: I see you have a 2011 (from your other post), as I do. My updater should work for you. I'll need an email, which likely should not be on a public forum. Shoot me an eMail at <deleted-file sent>.
I have 2013 MKT. Would this uodate work for my system? If so , may i please recieve the file? I saw the step by step post and will follow that if that applies to me also.
Unfortunately, no.
The '10 & '11's had Sync 1. you have Sync 2. Have you gone to the Lincoln update page to see if there is an update for your MKT?
