inmanlanier
- Jan 17, 2022
We're on our third trip of 725 miles both ways, and I have again noticed a bias in the car's centering behavior when on cruise control with the lane centering feature enabled. I noticed it during the first two trips - then the windshield got replaced which prompts a recalibration of the system. On this first leg out of state this 3rd trip - the same occurred. Today I tried a test (1 data point - need to validate with more) - I gently drove over to the right white line, and I noted that right when my mind concluded the tires were at or near the line the steering wheel chattered and the car torqued steering to the left. When slowly going toward the two center lines, however I noted that until I thought I was definitely further over to the left (i.e. onto the left most line) than the prior test, then the steering wheel chattered. On the interstate coming up, I noted that a couple of times it drifted gently to the left part of the lane on gentle right turns to where the tires were riding on the lane dividing reflectors before the system started to act.
So... I believe mine has a bias too far to the left.
Has anyone noticed a bias in your 'centering'? If so, what have you done about it? Does anyone know of or heard of a way to 'calibrate' the device or bias it either way?
I can't imagine trying to explain this to a service advisor so it can be accurately communicated to a tech. They'll likely hook up a test device and say 'it all checks out OK!'
