angore
 - Apr 3, 2024
- Location
 - Triangle area. North Carolina
 - 2024 Nautilus Premier Hybrid (Sheila)
Here is a longish video on the battery monitoring system.
From experience so far on my battery the resting voltage starts at 12.7v (solid green) but it will drop to at least 12.5v before the maintenance mode starts the charge cycle. From what I see on Internet from various AGM battery makers, the full charge can range from 12.7 to 13v. I will contact Noco.NOKO sent this to me …
Excellent video! I was watching a lot of his videos a few years ago. Actually took my '08 Expedition to him for a spark plug change. Weird dude but very knowledgeable.Here is a longish video on the battery monitoring system.
I'm so glad this information was fruitful for you, and I'm sure many others. This forum is a great source of information. If you look back, we had a few posts in this thread talking about where to place the negative clamp beginning at post #269.What I did not know until watching this, is that I have been re-charging with my Noco Genius 10 incorrectly. I had been placing the negative charger right on the neg. terminal. That explains why I would charge overnight and it could still take 30+ minutes and maybe multiple drives before Auto Stop/Start would begin functioning again. I was charging on the wrong side of the sensor.
Thanks for posting this!
Yep, I missed those, just like all the people who have missed my posts about the BCM lol!I'm so glad this information was fruitful for you, and I'm sure many others. This forum is a great source of information. If you look back, we had a few posts in this thread talking about where to place the negative clamp beginning at post #269.
It is not a better solution.... It is the only solution!Actually, I think a better solution would be one with it's own shunt resistor so you can monitor current draw as well. But this was on sale at the time.
Well Said! I agree.In my attempt to be a pain. I have tried looking at the owners manual on line to find the minimum speed/miles needed to be driven daily, weekly or monthly to keep the battery healthy. Still have not found the instructions mandating a charger to make the 2024 Lincoln Nauatilis Hybrid available to use. If it’s not in the owners manual and a charger was not supplied with your vehicle, it is not necessary. If ones vehicle is not holding a proper charge between usage it is somehow defective.
Why not every time a low battery condition occurs making vehicle unusable call Lincoln and have it towed to the dealer. If they can’t fix it, buy it back.
Been lucky so far only once had a issue. Although other day map disappeared from the 48" screen still was on the center stack. Took about 2 days then it fixed itself. Gremlins were busy.
Of course, with that PITA-to-access cabin fuse box location it gets to be a drag if someone actually wants to understand where the current draws are coming from (I'm not saying people should have to do this - the car shouldn't need diagnosing by owners - but some of us are the "inquiring minds want to know" types...
You need to monitor your amperage draw. With that, your understanding of batteries opens up a new universe in diagnosing!
You will attain battery basics 101 Nervana!
They did bury that box deepOf course, with that PITA-to-access cabin fuse box location it gets to be a drag if someone actually wants to understand where the current draws are coming from (I'm not saying people should have to do this - the car shouldn't need diagnosing by owners - but some of us are the "inquiring minds want to know" types)
Unfortunately it isn't clear that it would actually be useful for monitoring/assessing unintended parasitic drains, where the net idea is to pick up what particular things are consuming power, and how much draw, when the car is nominally turned off:They did bury that box deep!
You could always plug in one of these and download the free FoMoCo diagnostic software and monitor to your hearts content !!! I just put it on my Christmas wish list and hoping I don't end up with a lump FoMoCoal....
The Deltran (depending on model) doesn't provide that much current. We had one go dead in 90 minutes after driving for a half hour (all latest fixes). This is not a parasitic drain issue. This is a high drain issue, and a Deltran would not keep up. We've seen it once in 2200 miles, but no clue if or when it could happen again.I’ll report what happened today. But first, know that I try to stay ahead of battery issues by putting the 2024 Nautilus 2.0 ICE on a Delran Battery Tender every weekend when I know my wife won’t drive it for more than 3 days in a row. The Battery Tender usually goes to full trickle charge within a day, so I know the battery is always at peak charge.
OK, Thursday, she drove it 160 miles, no problem. (She deactivates auto-off all the time.). Parked it in the garage Thursday, and Friday (yesterday) I popped the hood to put it on the tender. The car made some odd clunks and clicks it usually didn’t make when I popped the hood. I put the Tender cable on.
Today we went to start it to back it out of the garage to get access to our lawn tractor, and the remote didn’t work, and the Tender was still in full red light charge mode. The car was dead as a door nail. The app notified us the car has gone into deep sleep due to low battery detection….while on the charger?!? I got in with the physical key, and there was nothing I could do after that.
We are currently waiting for Lincoln roadside assistance to jump it to see if it can at least wake the battery up. Then will keep both fobs in a Farraday box and put it back on the Tender. Then will see if it starts up Monday morning.
We are hoping the fobs are contributing to the parasitic drain, because, while not a perfect solution, at least if the fobs are contained in a Faraday bag, and that’s the fix, I can deal with that for now.
The fact we have a brand new $60,000 Lincoln that we won’t know if it will start or not is ridiculous. All software updates are up to date.
Insult to injury is my wife traded in her beautiful Lacrosse because of electrical gremlins.
Meanwhile I have an 18 year old Mustang GT…. THAT STARTS EVERY…. DAMN ….TIME.
FYI, ours was completely dead in the exact manner described. It took roadside assistance a period of charging before the vehicle would wake up, but it's been fine now for two weeks. A tender typically doesn't have the oomph to recover a dead battery.The battery must have completely died especially if kept it charged. If it will not accept the charge it is usually gone and from my experience it can sometimes so bad you cannot jump without removing the battery.
No, it's not. But you can perform a CCA test with a proper battery tester. It only needs to apply the proper load for a brief time. You can even perform it with a standalone battery.I'm curious what a CCA test would be on a hybrid. I didn't think the little 12V is actually used to start the car, though I could be wrong.
Both good precautions. FYI, we already had our fobs isolated when our quick drain occurred.So for now these fobs will always be shielded when not in use and I’m ordering a jump box.
