Hi Houtex. Only referring to fuel quality and octane ratings: You likely know this, but better safe than sorry.
Higher octane gas is not necessarily “better gas”, when compared apples to apples to regular or mid-grade from the same fuel company and gas station. It simply has more additives to increase the octane rating.
So as an example, if you go to a Shell station and buy 87, 89, 91 or 93 octane fuel, the quality of the fuel is the same. The difference between each fuel is simply the octane additives. Which is what also affects the price.
However, octane rating alone is not an indicator of fuel “quality”, when purchasing fuel from the same station.
On the other hand, overall fuel quality can vary between the stations of various fuel companies, which is a good reason to try and patronize only Top Tier fuel stations.
So yes, fuel quality may/will vary between stations from different companies. Not only in additive packages, but also in the care and overall quality of the fuels.
So again, better to stick to use Top Tier fuels than cheap, “convenience store” and off-brand stations.
In addition, yes, sometimes those fuels to various company stations are supplied by the same or similar refineries. However, the quality, additive packages, care etc. etc. can/still vary. And additive packages are a primary deciding factor in determining fuel “quality”.
Therefore, in your particular case, unless you require the full advertised power rating of your vehicle, you could go to 91, 89 or even 87 regular, and save money without worrying about injector issues due to fuel “quality”.
I understand and respect any choice you make.
Hope that is all understandable and good luck.
