Hello all,
New member here and needing some thoughts.  We purchased the Aviator two days ago and are so disappointed with the ride. We traded in our Nautilus that had such an amazing ride. With nobody in the front passenger seat you can see it moving from the vibration and bumbs in the road. From what we were told it would be a better ride not worse..  Any thoughts?
Hi MLG and welcome to the Lincoln Forums. First...what size wheels do you have. If they are 20"+, a harsher ride is one of the prices we pay to be stylish.
As far as what can be done...The first thing to do is check the tire pressures in all 4 tires. They well may be very high. Overinflated tires will cause a harsh ride.
Although Dealers are supposed to check and adjust the tire pressure as part of the Dealer Prep service (they come overinflated from the factory). it seems many do not.
You need to read the tire pressure placard on the drivers side door sill to see what the recommended pressure is. That is the "recommended
cold tire pressure".
Then use a good quality tire pressure gauge to check the pressure in all 4 tires. Ideally, in the early morning,
before you drive the vehicle and before the sun is hitting the tires on one side of the car. Then adjust them as necessary.
Do
not use the TPMS readout in the Driver Information Center to check and monitor your tire pressures. Use a good quality tire pressure gauge. Lincoln clearly tells us this in the Owners Manual.
If you do not already own one, buy one and keep it in the glove compartment or trunk. You can get one for $10-$15 at any big box automotive store.
If adjusting the tire pressures does not solve the problem, make an appointment with your Dealership to have it checked for issues.
