Hello, all.
Starting in 2003, Ford installed a "Drivers Door Module" as standard equipment in Lincoln Town Cars. This module assumed functions previously taken by other computers in the car, and added new "functionality." This functionality is best shown when the DDM fails and makes the entire car nearly unusable.
System-wise, the Drivers Door Module is part of the "Alarm System," which explains why it affects the windows and doors. Since "memory seat positions" can tie into the remote key fobs, seat adjustment is also affected for all models. Some versions of this module are actually labeled "Drivers Door Module" on the part number sticker. Some earlier DDMs may have the factory Keyless Entry Code on them printed on a sticker. Later ones will not have this sticker. New/New-Old-Stock in intact packaging will have this code printed on a separate glove-box card. This number can be read from a functional unit via Forscan or the Ford Factory Service Software.
2003-2005, Lincoln Town Car only. PN: 41WZ-15K602-AA. This part is called the "Anti-Theft Alarm Control Unit." It's also known as the "Module, Receiver, Processor-Multiplex, Door."
2006-2007, all Lincoln Town Cars, all Ford Crown Victoria, and all Mercury Grand Marquis as well. PN: 61WZ-15K602-B. Added Tire Pressure Monitoring System functionality. This part is called the "Tire Pressure Monitoring System Receiver. It's also known as the "Module, Receiver, Control Module, Kit - Keyless Entry - Cntrlr &"
2008, PN: 8W7Z-15K602-A, same description as 2006-2007.
2009-2011, PN: 9W7Z-15K602-C, same description as 2006-2007.
When buying this module used from a salvage yard or eBay, you should ideally get the same year, make, and level of "options" that are affected by the DDM as are installed on your car. If the make is different for 2006 and later, but the options are the same, the module should work, provided the base part number is also the same. Different part numbers will likely not interchange physically, much less electronically.
When buying new/NOS parts from "wherever," buy the same part number as fitted to your car. The part will work but only after being programmed. This can be done with the Ford Factory Dealer Service software, and does not necessarily require any residual functionality from the failed DDM. This might also be possible using Forscan, but I haven't personally used Forscan. I will defer to an experienced Forscan user for the details on that.
No one has claimed to have successfully "re-programmed" a used DDM in the field. This may be impossible, or may just be FoMoCo FUD designed to sell new parts rather than dealing with re-flashing a used part which may or may not stay "fixed" after re-flashing.
If anyone has attempted to re-flash a used DDM in the field, could you reply with what you used, what you did, and if it succeeded or not?
Thanks.
