FYI … this is what I got from NOCO … which is why I got to the battery and connected to its + and - posts.
“If you have both positive AND negative remote posts, you could connect to them, but if it is only a positive remote post, that is for jump starting only and not battery charging and you would need to directly connect to the battery to charge it.
You can use the GC002 1/4" eyelets or GC008 3/8" eyelets to mount to the battery.  Then when you need to charge, you can just hook the charge to the cable.
Regards,
Chris G
NOCO Customer Support Supervisor”
