I'm curious to see the statistics on Lincolns that flat out completely fail electrically so as to only allow the key to enter and then magically start with the fob.
Are backup pass-codes stored in the phone or elsewhere? If in the phone then that won't help.Not true. If you have programmed the door code and backup passcodes, you will have no issue.
Have you set up PAAK? If not, then the phone will do nothing. If you have, and it does nothing, your RFA module needs to be re-flashed.Are backup pass-codes stored in the phone or elsewhere? If in the phone then that won't help.
You mentioned that the phone will act the same as the keyfob. My phone will lock/unlock the doors and start the engine but only if I use the actual buttons on the Lincoln Way app. Approaching the locked vehicle with the phone on me does nothing.
Thank you for the explanation. The concierge at my dealership set up the PAAK and as mentioned, I can perform all the functions of the Lincoln Wat app by using the displayed buttons on the phone but that is it. I will be making an appointment in the next few weeks to have the winter tires installed and will ask them about the RFA module re-flash. Appreciate the info.Have you set up PAAK? If not, then the phone will do nothing. If you have, and it does nothing, your RFA module needs to be re-flashed.
I don't know what you mean by storing codes. Are you asking how the vehicle knows the codes? You set them up in the vehicle and it stores them that way. If you are asking how I know what my codes are, yes, I have them written down in my iOS Notes. I would only need the code(s) if my PAAK is not being detected by the vehicle. In the last 3-4 weeks since my RFA module was re-flashed, that has never happened. Happened all the time prior to that and also in my 2020 I used to own.
OK...I am new to all this. When you say "door code", are you referring to to the keypad on the door pillar? What would be the purpose of "backup" passcode(s)?Not true. If you have programmed the door code and backup passcodes, you will have no issue.
Yes. The backup passcode allows you to start the vehicle if the PAAK device is not detected. Same for the door code. Allows access to the vehicle if things go awry with PAAK.OK...I am new to all this. When you say "door code", are you referring to to the keypad on the door pillar? What would be the purpose of "backup" passcode(s)?
a few old time customers had vintage lincoln convertibles, as you have pictured in your signature!
Did you ever get your PAAK issue resolved? If so, what fixed it?The boss literally hates the Aviator so I am running out of time. It's a very comfortable car (seats/air suspension/etc.) but the tech is horrendous. PAAK worked fine on both of our phones, but it would never return her to the proper seating position. I noticed that my profile disappeared recently even though everything else worked fine. I created my profile and it would disappear every time I started the car. Lastly, the screen would randomly go black and/or the navigation would not load. She had enough so I performed a hard reset which resulted in a black screen for 15-20 minutes until it finally started up. I was able to create a profile and it would save as expected. But, I noticed it would not save my profile to my phone AND key. I believe this was due to PAAK configuration being removed. I deleted the profile and went through the process and EVERY single time I set up PAAK, the app would error w/ pairing failure. I spent 45 minutes with Lincoln Support via phone and performed the following:
Hard reset
Rebooted iPhone
Remove Aviator from bluetooth
Removed phones from Aviator bluetooth list
Reinstalled the Lincoln app
Updated to latest 3.4.3188 version
Same pairing error over and over. Lincoln Support said the latest version would fix all of this. It didn't.
Welcome to the Forum.Did you ever get your PAAK issue resolved? If so, what fixed it?
Thanks. For the benefit of others, I thought I'd ask since I have a very similar issue. My PAAK stopped working out of the blue on my 2020 Aviator a couple months ago and I'm pretty motivated to get it fixed. When I get in the vehicle, the app on my Pixel 7 switches back and forth between connected and disconnected, and it won't start without the fob. I called the concierge and they walked me through the whole removal of the app and reset of PAAK, etc. Now the app fails to complete setup every time I try it, but ironically I get a notification in the app saying PAAK is enabled for my phone during setup before it fails. I think there's something wrong with the low energy Bluetooth antenna/module for PAAK preventing my phone from actually communicating via low energy Bluetooth with that module. I'm not sure if that's also called the RFA module, but I did find two SSMs (49968 and 50845) that I shared with the dealer when scheduling my appointment, so I'll circle back with whatever they find. For completeness, my remote start and door locks work great through the app and Bluetooth phone connection, Android Auto, and music all works great, so its just the PAAK connection that refuses to connect.Welcome to the Forum.
Hopefully, the member is still following. He was last seen here in March.
Same issue with my Pixel 7 on my 2022. Been through all the steps with concierge too. Now wondering if Pixel 7 possibly has a unique issue?? Please keep posting on anything you find. Thanks!Thanks. For the benefit of others, I thought I'd ask since I have a very similar issue. My PAAK stopped working out of the blue on my 2020 Aviator a couple months ago and I'm pretty motivated to get it fixed. When I get in the vehicle, the app on my Pixel 7 switches back and forth between connected and disconnected, and it won't start without the fob. I called the concierge and they walked me through the whole removal of the app and reset of PAAK, etc. Now the app fails to complete setup every time I try it, but ironically I get a notification in the app saying PAAK is enabled for my phone during setup before it fails. I think there's something wrong with the low energy Bluetooth antenna/module for PAAK preventing my phone from actually communicating via low energy Bluetooth with that module. I'm not sure if that's also called the RFA module, but I did find two SSMs (49968 and 50845) that I shared with the dealer when scheduling my appointment, so I'll circle back with whatever they find. For completeness, my remote start and door locks work great through the app and Bluetooth phone connection, Android Auto, and music all works great, so its just the PAAK connection that refuses to connect.
Will do as both my wife and I have Pixel 7s.Same issue with my Pixel 7 on my 2022. Been through all the steps with concierge too. Now wondering if Pixel 7 possibly has a unique issue?? Please keep posting on anything you find. Thanks!
I would use the help feature in the Lincoln Way app and connect to them. They will walk you through it and are usually very good at their jobs.Alright - now all of you folks have me interested. Neither my wife or I use the feature but conveniences are ofttimes nice to take advantage of.
Seeing some talk of various details, setup requirements and the like, is there a good reference source to read to completely and properly set it up? I think I may give it a try.
