Takeapic
Is there a software update to address this?It is a software issue per actual Lincoln dealerships.
I hope that is the case and it is an easy fix!It is a software issue per actual Lincoln dealerships.
Do you know any specific details about that? A Service Bulletin number perhaps? Something to point to when one visits the dealership service department is always helpful.It is a software issue per actual Lincoln dealerships.
As usual, they will test drive the vehicle to find it. Example at what accelerated speed and/or RPM does it occur most times will help service tech.Do you know any specific details about that? A Service Bulletin number perhaps? Something to point to when one visits the dealership service department is always helpful.
I've decided to wait until they know more about the problem. It is over an hour to the closest dealership and they are running short on loaner vehicles. I'm just going to turn off the auto/start each time and live with it for now. My gas mileage has also improved. Hopefully I can get this addressed soon.Following. I’m curious to hear if there is a fix for this issue.
Mine is still having problems even with the auto/start turned off. I may try to take it in next month. It is just a pain to get it there and run the risk of not getting the issue solved!Hi, I also have the same problem on my 2020 Nautilus 2.0 FWD and I been taking it to the dealer in different occasions but still have the same issue. I imagine that Lincoln knows and will eventually find a solution for this annoying problem.
My Nautilus 2.0 FWD is very difficult to operate smoothly at low speeds, such as parking lots or ceeping traffic. My dealer did an update on the transmission to address bumpy downshifts, which helped a bit. Still, slow driving is jerky most of the time as you try to vary the speed. Just can't seem to smoothly give it a little more throttle.
Anyone else noticing this, or any ideas what to get checked by the dealer?
Your on the right path but saying slow speed is not quantitative enough. Track at what RPMs the slow points. Let’s say it occurred at 30 mi / hr at 1,200 rpm and 40 mi/hr @ 2,000 rpm. It is a software issue but it could be not only the transmission update, but also software update on say the fuel injection. It is solvabl, nothing broken but the regional engineer needs specificity. Also after you provide this data, ask dealer if “Regional Engineer” is in the loop, if not, request that. Good Luck!I am having the same issue
Whatever happened to taking your vehicle for service and having the techs/mechanics fix the issue without calling for a "lifeline"?I have the same issue with my 2021 Nautilus 2.7 AWD. My dealer says ,they are waiting for manufacture's response, how to fix this problem. It is very annoying to drive in slow traffic.
This is a software issue that will involve your dealer communicating with the regional office’s engineer. It is solvable but I would suggest you reference the approximate RPM from your left tachometer gage. For me it happened at around 1500 rpm & 2500 rpm. Good Luck!I have the 2.0 AWD. You can feel it shifting up and when you slow down to stop you can feel it shifting down. I’ve only had this car two weeks not even 200 miles on it, I will wait a little more and then I will take it in but it’s frustrating that a car that cost this much money drives like that.
I have a similar problem with my 2022 Nautilus Black Label 4wd, but in the reverse scenario. When accelerating from a dead stop and while still in first to second gear, the car lurches, shudders, and hangs back. It is NOT a smooth acceleration. I took it in to the service center and their transmission expert took the car out for a long drive and reported that the powertrain is functioning normally, i.e., the way it was designed to, and there is nothing wrong with it. And nothing that could be fixed via firmware update, according to them. It is NOT a matter of the system "learning" my driving habits, any longer.This is a software issue that will involve your dealer communicating with the regional office’s engineer. It is solvable but I would suggest you reference the approximate RPM from your left tachometer gage. For me it happened at around 1500 rpm & 2500 rpm. Good Luck!
Keep in mind that there doesn't seem to be a great volume of complaints about this issue. All parts are subject to failure at some time or another no matter who manufactures them. Also, I would feel very confident stating that the 1964 transmission wasn't anywhere as complicated as the 2022 transmission. I don't know for sure if these transmissions still have that adaptive learning like earlier models but you could always try disconnecting the negative battery cable for a period of time and see if that helps. Just remember that you may lose some saved memory settings. It might also be an issue with the PTU....................................................
Sixty years of designing automatic transmissions and this is the best they can do?
The transmission in my first car, the magnificent 1964 Buick Electra 225, performed better than this.
I am shocked and very disappointed in Lincoln.
