Keyless entry not working.
Welcome to the Forum.
Did you remove the DDM (Driver door module) from your old door and install it in the new/replaced door. What year was the new door from? Each DDM has a factory code printed on the DDM so you need the code for the particular DDM you have installed to operate the keypad. The factory DDM code is printed on the DDM in the forward part of the door. It has lots of wires attached.
The currently installed DDM may not be working correctly or missing a connector, so perhaps replace with the DDM from your old door.
Hello thank you for responding
I changed the door and put the old Ddm in it worked fine but I had to send it to a body shop to straighten the hinges when it came back the lock/unlock and mirror switch did not work nor the keypad I had the key pad from the new 1995 donor door so I tried it. it lights up when you unlock the door with the key fob but if you push any buttons nothing happens so I put the ddm that came with the new door same thing
If you say that's symptoms of a bad ddm I will pull another one and try it
Eagerly awaiting your response
Baja
I don't understand why it was not working after the hinge repair when it worked fine before. Did you check all the connections to the DDM before putting the other DDM in?
Putting in another good DDM may fix the issue, but it may be the wiring. I will find the electrical diagrams and see if I can see a diagnostic for testing the circuits.
My 2004 Town Car Ultimate key fobs stopped working 18 months ago, then I got the intermittent Door Ajar thing and was forced to deal with the DDM. Replaced the original with the same part number from same model year and everything seems to have come back. No download/upload, no trip to the dealer (so far) - just need to remember new door code.
I have a 1997 Continental and have been busy replace parts on the car. Sentimental value mostly, belonging to parents. I have encountered a problem in the driver's door and have twice replaced the DDM. it follows a similar pattern. The car sits outside and we just had 4 days of heavy rain. The driver door ajar report started coming on. The trunk popped open twice. Then the internal light starts staying on until it automatically fades off. Now the keyless entry has stopped working and today the door locks popped up while driving. I found one used DDM and have ordered it.
I clearly have some kind of electrical short happening. Do you have any suggestions for where to start testing circuits and testing the DDM? I am digging into it via manuals and wiring diagrams, but it is a bit of a bit of pain with my big mits. I suspect the door switch is damaged with possible wire damage that is shorting when wet. Would that be enough to damage the DDM?
The second question is does anyone know where I can get the DDM refurbished. I have the two older failed ones and I can find no more new ones on line. I never tossed them thinking if I had too I could find someone who could repair them. I actually have replacement modules for virtually everything else.
If I can not isolate the short, is it possible to jump out functions so I don't fry this next DDM. I honestly am not confident there is supply around anymore. Any advice will be appreciated. I would also appreciate any advice on where to find the water leaks that are causing it and getting my paws onf trim parts and seals.
I had a similar problem in my 04 Ultimate! I got Wiring diagrams and watched tons of YouTube videos on electrical trouble shooting! I even bought wire tracers and a Load Pro to test the wires! But, in the diagrams everything pointed to the DDM! So, I went to the U Pull and Pay and eventually they got one in with the same part numbers as mine! Months and months of reading Service manuals and how to read schematics videos and finally I was about to test something! But, first I changed the Driver Door Module and-Presto! Radio shut off, Power seat, Mirrors, Door locks, trunk release, Keyless entry, courtesy exit lights etc all worked again! 1 $20.00 plug and play part!!!
After intermittently working/not working for 2-3 weeks, the problem went away. The key fob & the exterior door pad all work perfectly once again.
Suggestions as to what may have cured the problem?
I know it is old thread but I think it's the keyless entry module that's located behind the glovebox to the right
2003 Cartier here with similar issues.
TL;DR - I have a bad DDM or the wiring in the door (or one of the things connected to the DDM, if they can cause this problem) is damaged somehow and is causing the DDM to act like it's gone bad. with all the associated symptoms (and no blown fuses). My mechanic thinks it's the wiring by the door from opening/closing, and it's even more likely than usual since the wiring has previously had issues before and there are some visible repairs, heat shrink tubing and all, and I could've damaged the wires by spraying water near those areas. I'd probably just buy a used DDM first, that I could easily install myself, if I knew that the same model number DDM is all that is needed to ensure it gets along with the rest of my car (as opposed to same model and/or trim level and/or features, etc.) and if I could (practically?) rule out wiring without it being as crazy difficult and easy to screw up as it appears to be.
END TL;DR
It started months ago - key fobs stopped working, tried to reprogram them from scratch, no luck, couldn't be sure that anything I bought online would work or work for very long.
Gave up on that.
The rest happened almost all at once in the span of a few days or so.
The side view mirror controls stopped, the trunk release stopped working, the power door locks stopped working, the keyless entry pad stopped working, the power seats stopped working last, and then after the "easy entry" was able to signal to the seat to go all the way back and with no way for me to stop it, now I can barely reach the pedals (particularly since the seat was set back an additional several inches at the factory for the quite tall original owner).
After trying to replace any relevant fuses (that looked fine anyway) and then using a multimeter to test that they are not bad, and looking into it some more I noticed the commonality.
Everything points towards something to do with the Driver Door Module and I know how to get to it easily, it's exact model number, even found a few I could buy, but my mechanic (really great guy, loves my car, been working on Fords for decades originally as part of a Ford dealership) thinks it might be the wires by the door from opening and closing it over the years. I had called to ask if he can program the DDM if it turns out to be that, but he said he'd have to order it to come programmed and from what I gathered that could be over 10x as expensive as a used part, that I would prefer to go with, assuming that the part works on my car, if I knew that it would.
It seems like the specific part model number varies a lot (by year only? by trim level? by specific features too?) but I don't know if that alone is enough to know it would be programmed to work on my car. My searches have come up with inconclusive information. I don't know if I would need to get a specific model number DDM from a car with all the same features I'd need it for (as some have suggested), or if a range of model numbers from nearby (car) model years would work but it also needs the exact same features that would need to be determined another way, or if simply the correct part model number would be enough. None of the local salvage yards seem to have an 03 Cartier, but I think there was an 04 Ultimate as about the closest
On top of that, there didn't seem to be any mention beyond that I'd need to record the new keyless entry code. Would it also affect the key fobs? Would that all work nicely with the rest of the car and allow me to program the key fobs from scratch, or is the transmitter code stored somewhere else in a computer waiting for a working DDM to ask for it and then as soon as I get one that works, those key fobs will start working again like nothing happened and I can create more whenever I want to off of them?
If I knew this information, that it would be a sub-$100 part that's easy to replace, only need to match the model number of the DDM, and it wouldn't cause me any difficulties beyond having to relearn the new keyless entry code, then I wouldn't hesitate to buy one now to try first.
But the potential wiring problem seems very possible as well, maybe even more so based on other details, but I couldn't say what is more likely and I can't seem to diagnose it myself even though I would like to - in theory.
I got some wire repair tools, watched some DIY videos, and tried to learn how to locate where a short or open circuit might be located from (still don't really know how I would, especially with only a multimeter, not a test light or those signal/receiver things), and when I got a better look at all the wires coming into that door again, I was completely overwhelmed and have no idea where I would even start.
I had replaced the driver side mirror myself when it was cracked, and disassembled that panel to get to it. It's relatively easy to get to the wire harnesses and connectors that clip directly into the buttons on the driver door panel, which just pops out, but tracing them a short distance leads to a giant tightly wrapped bundle of utter confusion.
I spent a lot of time trying to find wiring diagrams, but even if I did have them, I'm not sure it would help me much in making sense of physically locating each wire (removing the door? unwrapping the electrical tape? tracing wires individually from their outputs?). Would it also give me the information I needed to know if enough current was running through them, or the right voltage was sending the proper signal to the various control modules? I once had minor knowledge about circuits but practically little experience.
Regardless of if I could figure it out, if it's in or near the accordion boot, I fear making a gigantic mess that I can't then undo or further damaging wires while trying to repair them or leaving them situated in a way that during normal use they will get stretched or rubbed on and then fail prematurely because of my attempt. However, this time, I did notice several heat-shrink tubes where wires in the door panel itself (before they split off into a handful of large bundles instead of one gigantic one) must have already been spliced and repaired, although I'm not sure when that was done or why.
I think I might have had issues with the windows before - and months ago, while the driver side window goes down easily, unless I push it quite hard and at just the right angle, it won't go back up.
On top of that evidence that the module itself might be okay but the wiring itself isn't, I had issues with wasps making nests behind the mirror itself and in cracks and crevices along the door frames and pillars since I wasn't driving as much due to lockdown and so they made themselves comfortable, and I tried to flush them out at night with water somewhat carefully but I could have flooded the side view mirror in the process or inadvertently splashed enough onto the door itself that it misted or dripped into the panel when I had the door open to get in between. I got rid of most of them, but they came back pretty quickly and eventually I sprayed them with pesticide (which comes out like a foamy liquid) and then, so that me and my cats (who like to rest on or under the car) would be minimally exposed to those chemicals, I washed off the same areas with water to remove and dilute it.
Is it possible that there could be some sort of downstream effect from the side view mirror wiring being damaged by that? Could a short or open circuit caused by corrosion or other damage to the wiring cause some sort of signal (or lack thereof) or feedback that prevents the DDM from working without destroying it outright, that could be resolved by fixing said wire or wires?
In the meantime, I may need to drive the car a bit more, and I've resorted to using a couch cushion like a booster seat, while the seat itself is all the way back and, as well, leaned back much farther than I prefer. It's not particularly safe for me should I be in an accident, and I am probably more likely to be in one given how uncomfortable and unfamiliar the positioning is and how much less support I have in that position from my seat.
I think I'll make another post asking for help with that as well, since I tried fruitlessly for hours to find out how I could move the seat forward, and the closest I've gotten at this point is, remove the seat, then do something, and merely removing the seat might be literally impossible for me without doing something more drastic than I have tried.
END TL;DR
Gave up on that.
Hi, Nr86.
Since I can't see your car from here, I'll assume that you know what you're seeing, and address your concerns starting with the wiring. However, the Drivers Door Module is still the most likely culprit, and should be replaced first. Unless your car has higher-than-police-car mileage, I don't think the wiring harness is damaged
If the wiring harness in the door is messed up that badly, you will need to replace it completely starting at the connector where the door harness connects to the rest of the car. Do not try any more splicing. People thinking that they knew how to make splices that would work for the long term is part of what got you to where you are, if the wiring harness is part of the problem.
Before you replace the door harness, you will want to locate the connector on your car. Disconnect it, clean the contacts, and reconnect it. That might clear up or reduce the severity of the wiring problems.
If it doesn't, you still needed to find that connector, since you will be replacing the wiring harness to that point by unplugging the current one and plugging in the replacement.
If you do end up replacing the wiring harness, the 2004 Ultimate's wiring harness should do the trick.
I would also re-install the driver's seat in the "standard" location once you're able to do so.
The problem with your window as you described it would be caused by a failing window regulator. Replace it.
This all comes back to the likely common culprit, the Drivers Door Module. You will need to replace it. While the failure sequence could be caused by the wiring, the DDM is a much more likely culprit since your car hasn't caught on fire.
The "base" DDM is the same part number for 2003-2005. The differences are in the programing for the various options. While a 2003 Cartier would be much better, the 2004 Ultimate should work if the car has the same options, and lacks the same options as yours does, I.E. memory seats, yes or no; seat heat, yes or no. Since the Cartier and Ultimate are both the "top" trim levels for the given year, your and the 2004 Ultimate likely have the same options.
The DDM should have a five digit number on it for the Keyless Entry (keypad on door) system. If it does not, you will need to have your mechanic "read" it from the DDM after you install it. The key fobs will need to be reprogrammed as per the owners manual. Reprogramming them will in fact "prove" that at least that part of the DDM is working.
[...]However, the Drivers Door Module is still the most likely culprit, and should be replaced first. Unless your car has higher-than-police-car mileage, I don't think the wiring harness is damaged
[...]The "base" DDM is the same part number for 2003-2005. The differences are in the programing for the various options. While a 2003 Cartier would be much better, the 2004 Ultimate should work if the car has the same options, and lacks the same options as yours does, I.E. memory seats, yes or no; seat heat, yes or no. Since the Cartier and Ultimate are both the "top" trim levels for the given year, your and the 2004 Ultimate likely have the same options.
Alright, Brian, I'm thoroughly sold on getting a new (used) DDM (and not futzing with wiring until that could be ruled out definitively).
I hope the part number will match (3W1T instead of 4W1T, etc.), but I suspect it might not, even if the car has all the same features/options and based on what I could find it seems likely that it will have all the same options.
I guess I'll see, but I will have to go to the pick and pull first.
I might have given a misleading impression of the window issue since I was mentioning it only to provide more (possibly-relevant?) details about the main problem, not to ask for even more help with another one without starting a new thread and/or waiting. But since you volunteered... :)
The way it works, the button for the window to go down works like normal, no problem whatsoever. The one to raise it though, I found that I have to press down hard (hard enough that that surface of the console compresses a little) and sort of toward the side, and once, I assume, it makes sufficient contact and starts moving, I just hold my hand completely still while the window works like it normally would. Any movement off of that sweet spot and it stops again.
Couldn't it be the buttons/switches/connectors themselves? Or still no?
If I'm going to a pick and pull and the parts are identical, it would be almost trivial to replace, whereas the regulator seems a bit more involved (and cheap enough to buy new anyway that that is probably preferable).
Anyway, thank you for the extremely quick and thorough response. I'll surely be back, and hopefully I can report on some success that might be useful to others as well.
Hi, Nr86.
The door switch contact can be cleaned with a typing eraser if you are good at "switch surgery." Otherwise, since you're snagging parts off of that '04 Ultimate anyway...
Service or replace the window switch before messing with replacing the regulator. Replacing the switch only requires a couple of plastic "pry" tools and some patience. Servicing the one you have right now only requires a couple of additional tools, namely a typing or pencil eraser, a small Torx bit and a couple of small straight-blade screwdrivers, along with a small quantity of silicone grease.
Removing and replacing the regulator is much more involved. If you have to replace the regulator, new is prefered. After all, the "replacement" part from the pick-and-pull has likely lived the exact same life as the one you're replacing. So, even with lubricating the flex-cables on the replacement before installing it, how much life does it have left?
I started a new thread about the "base" part numbers for the DDM. That should answer most of your questions on that.
For posterity, I fully (excessively?) detailed a working fix (replacement) for my apparently-failed DDM under Brian J. Patterson's thread titled "The Dreaded Drivers Door Module Part Numbers"
The first, salvaged DDM with part no. 4W1T-13C791-AA from an 04 Ultimate Town Car at a salvage yard did not work besides giving me control of my power seats. A bust but not a particularly costly one.
The second, used DDM, still substantially cheaper than a new one, with identical part no. 3W1T-13C791-AF (my old one is featured below) so far has given me control of everything I can think of. I made sure to record the new keyless entry code which works by default. Happens to be right on the sticker at least up until these years.
Success!
Success!
Hi, Nr86.
Glad to read that you got your Town Car operating again, and that it was in fact the DDM causing the problems.
I am relatively new to the "Panther Town Car" community, though I have worked occasionally on collectable cars for most of my life. This experience has given me at least some insight in using parts manuals and lists to identify parts and where they can be interchanged with the identical part on a more numerous car. Sometimes, parts can interchange. Sometimes, not.
In your case, the "first" DDM from the '04 proved that the wiring was likely not involved in causing the problem. The "second" DDM, with the identical part number to your original one provided the total repair. One should actually be concerned if it hadn't.
The problem(s) I've seen around the DDM in this forum come from those people who for whatever reason can't get the "original part number" part and try to use "something else," as in your case with the '04 DDM where the catalog listings said that it should work.
In the case of a new or NOS part of that part number, it likely would work after being flashed. At least this is what the factory is claiming, and I don't have a personal Rolodex of Lincoln Town Cars to prove or disprove it.
Since many people either wish or are obliged to not flash replacement DDMs, your quickly and economically finding the "as-built" replacement in good order is exactly what you needed. This proved out when you installed it and everything worked again.
Unless you really want to learn the wonders of Forscan (etc) you don't need to get that '04 DDM to work, since you got the "as-built" DDM fairly quickly. You can sell that one on eBay. This will get your money back and possibly another Town Car back on the road with working seats, windows, and so on.
Thanks.
The keypad on my car is working but the numbers is not illuminating when I press any number .
Hi, Mubarakma.
If everything else "DDM related" works, I would suspect a dirty connection to the keyless entry pad, or the keyless entry pad diode lighting, I.E. the keyless entry pad itself, or the DDM.
Using the schematics for your year of Town Car, apply 12vdc to the positive pin, and ground to the negative pin of the light circuit. If you connect this correctly and you receive no light, the problem is the keypad. If you receive light, the problem is either the DDM or the car's wiring.
In 2001, the power is supplied directly, and the ground is applied by the DDM. In earlier years, the power is supplied by the DDM, and the keypad is wired directly to ground. Verify (and fix if needed) the non-DDM circuit, test the continuity of the DDM "light signal" wire from the DDM connector to the keypad connector, and if the problem persists, it's the DDM.
If your Town Car is 2001 or newer, the replacement keyless entry pads are available from Tasca for $83.35 plus shipping, etc. For 2000 and earlier, the part is discontinued and rare outside of salvage yards.
If the problem appears to be the DDM, and everything else "DDM related," including your ability to unlock and lock the car with the keyless entry pad works fine, that would be a "judgement call" to fix. Myself, for only that, I wouldn't bother.
[updated and corrected after I realized I was working off of the 1995 schematics, which are not what you would be looking at on your car.]
Hi, Mubarakma.
Thanks a lot Brian for your detailed explanation my car is 2001 Cartier and I will trying to fix it myself but in October because the weather is not supporting still we are in summer and temp is over 41°C "over 106 F "plus humidity
It will be appreciated if you share schematic for 2001 model if you have it.
Thank you again
Thank you again
Hi, Mubarakma.
Post #2 in this thread, written by @Town, has the most needed extracts. The keyless entry pad is shown on the last page of the top-right of the four attachments, named "2001 Lincoln Town Car DDM keyless entry.pdf"
This article also has a hyperlink to a post in another thread on this forum with removal instructions for the driver's door trim panel. That attachment is MS Word ".doc" format. If you don't have Microsoft Word, the free Microsoft Word "Doc Viewer" will also open it.
Thanks.
@Town, I have a 99 Town Car Signature Touring. It seems to have all the symptoms of a dead DDM. If I replace it with a DDM that has a known code, do I still need to suck out the data from the old one and upload it to the new one? Can ForScan read/write the DDM?
Town hasn't logged in since Feb and it's very doubtful you'll get a response.
It would be best if you started a thread of your own, describing the problem in detail for some fresh advice (y)
Done, thank you.
Old post but other than "door ajar" did you lose any power options such as seats, mirrors or trunk?
