Radguy
Mine has a washer for the rear camera (2021 Grand Touring fully optioned). When the rear camera is activated, if you pull on the wiper lever to wash the front windscreen, the rear camera washer is also activated.
The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
Ahhhh, the good old days.Mine has a washer for the rear camera (2021 Grand Touring fully optioned). When the rear camera is activated, if you pull on the wiper lever to wash the front windscreen, the rear camera washer is also activated.
^^ Welcome to the Forum Rick.
Just wanted to add my coments to your concerns.
1. Any adjustments to the seats should be made prior to driving. Having said that, the passenger can adjust the seats while the vehicle is in motion. I don't see how making adjustments could be a liability,
3. I've only used 1 colour (Ice blue) in all the vehicles I've had so I personally don't see a need for more choices.
6. The rearview mirror camera is available on lesser value Ford products. I don't see why you'd want to go from a full screen view to a smaller one especially with all the sensors and cameras.
I'm sure that may owners would like to see changes to the current available setup. That's just a given, but I'm happy with what I have.
Good luck and enjoy the ride.
Welcome to the Forum Robert.Two things that could be improved. Have the front camera display come on automatically when you put the vehicle in Drive. Many other brands I've driven have the front camera come on when the car is in drive and it goes off after reaching a set speed. The second thing that bugs me and could be improved is a setting that that tilts your right mirror all the way down when you put the vehicle in reverse....
Yes! The perfect behavior would be to have the cameras come on automatically at slow speeds, with the forward camera if in drive, and the rear camera if in reverse, and automatically switch between them as you switch between forward and reverse. An alternative behavior would be to have the camera behave as now (only come on when you are in reverse and when you press the camera button) but once it is on, and your speed remains below the existing cut off, then it automatically switches between front and rear as you switch between forward and reverse.Have the front camera display come on automatically when you put the vehicle in Drive. Many other brands I've driven have the front camera come on when the car is in drive and it goes off after reaching a set speed.
Notes:
1) Yes the camera automatically comes on when the car detects an obstacle, but that is different.
2) There has literally never been and single time I have been in drive and wanted to see behind me, or been in reverse and wanted to see in front of me (beyond what the 360 degree view provides).
I believe this is something new with the 2025 model. My 2025 Aviator will trigger the front camera on occasion when pulling into the garage or when pulling in behind a vehicle/obstacle in a parking lot. Neither my 2020 nor 2023 Aviators did it.Did a test today with my 2022 Aviator. Put a fairly large cardboard box about 10 feet in front and slowly moved forward. The front camera did not turn on, but now my box is flattened for putting into the recycle bin. Has anyone else tested this to see if the front camera comes on ?
Exactly rightnot to speakfor the OP, but if you have little kids… in car seats/booster seats, you want the ability to adjust it on the go.
I agree with your wife’s input (& yours). There are many things that make the Aviator NOT female friendly (or for shorter/smaller person):More settings tied to the driver memory setting. I like auto hold, my wife does not. Guess which setting is kept off almost 100% of the time.
The bass on the revel system can at times be impressive but seems flat more often than not. Seems like someone at Lincoln believed that "feeling" bass wasn't luxurious. My MKT has fuller richer bass over a larger frequency range, but i think that has a 10" woofer vs the 8" in the Aviator. The "sweet spot" of that 8" woofer is narrow so there is a peaky and narrow frequency range that drops off quickly. Most of the time it feels like the 6x9s in the doors are doing more of the bass work. Lets down an otherwise amazing sound system.
More control over the drive modes. My MKT allows me to set the handling feel for the two available drive modes meaning i can have smoother throttle and sharper handling by setting D to sport handling. The available modes on the Aviator seem to change throttle, transmission and AWD settings with no real noticeable difference to ride and handling.
Don't drop park assist, but DO make it simpler. My wife uses park assist all the time on the MKT, it's the one feature that sold her on getting that car. She NEVER uses park assist on the Aviator because it's too complicated for her even after i gave her a tutorial. When I told her Ford was dropping park assist as a company her response was "guess we're not getting a Lincoln next time"
We ended up with a 6 passenger reserve despite the wife's trepidations, the ideal configuration for us was a 7 passenger grand touring black label..... This was never offered. You can get the grand touring as a 7 passenger and i think the black label was also available as a 7 passenger.... why not the BL GT? Would have made our conversations about which trim to get much simpler.
It's already been mentioned in this thread but build quality. My hud has visible NVH tape hanging out, my infotainment screen occasionally rattles. I have a strange clunk in the drivers door over large bumps that sounds like the door itself is loose, my passenger door has a rattle in the speaker like it's not mounted properly or is interfering with something in the door. The drivers power mirror is jerky when in folding/unfolding. One of the clips in the rear passenger door was installed at an angle and never pressed in all the way leaving a visible gap. The exterior panel gaps aren't consistent and even the paint has defects that seem odd on a vehicle in this price range. Don't even get started on the recalls and TSBs out there on this car. The car only has 15k miles at this point. My MKT had nothing like this and at 10 years old is still chugging along without any real or perceived quality problems.
I've had several Lincolns and despite the flaws I'm happy with my Aviator. As someone with brand affinity I'm more likely than most to be forgiving of these concerns, but I can imagine many people experiencing this after coming from a Benz or BMW or any other lux brand and being turned off from the Lincoln brand for life. Which is painful to imagine for someone who wants to see Lincoln at its very best
It remains to be seen how the 25 Aviator fares vs the above concerns and as someone who buys and hangs onto cars for a long time my next one is likely to be a 2028 or 2029 model, which will probably be a whole new platform by then.
Aviator Black Label. As soon as the car is turned off, the vehicle should lower itself to aid in exiting. Wireless Android Auto...seriously cannot believe this was not automatic.Lincoln executives have been watching this community for years. They've also made improvements to their vehicles based upon what they've read here. They are listening to you.
This discussion will serve as a quick and easy way for Lincoln executives to gauge interest and help make decisions moving forward.
As am Aviator driver, you should state exactly what you'd like to see enhanced, added, and/or omitted from your Lincoln Aviator.
Any posts that don't stick to the subject matter will be moved elsewhere.
I see more and more manufacturers deleting fog lights. Given the improved lighting systems, I seldom need them. I live in the country and have maybe used them once or twice in the last ten years.For the 2026 Aviator bring back the fog lights and wireless Apple Carplay.
