I was able to get a video because when this happens, it will happen subsequently if I don’t wait ten minutes between starts.
https://youtu.be/sccPF2u0buU
The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
video is privateI was able to get a video because when this happens, it will happen subsequently if I don’t wait ten minutes between starts.
Okay. I thought I could do that and share it with whom I wanted. I’ll fix it shortly.video is private
In my case, it lasts through an entire ignition sequence. I could drive for 30. minutes or more, well more than enough time to charge my battery IF it was low. But, if I turn off the engine and restart within 5-10 minutes, I still have the same issue. And, it is for all warning chimes throughout the cycle.I find it handy in a roundabout way in that I get some kind of notice before the battery gets low enough to actually trigger the Low Battery warning.
Same as mineIn my case, it lasts through an entire ignition sequence. I could drive for 30. minutes or more, well more than enough time to charge my battery IF it was low. But, if I turn off the engine and restart within 5-10 minutes, I still have the same issue. And, it is for all warning chimes throughout the cycle.
Welcome to the Forum.Was this ever resolved for you guys? Cuz I'm having this similar issue with my 20 aviator......................................
I’ve taken mine in Twice for the chimes. 2 different dealerships. Still not fixed. They said they charged battery , reset a code.F
i took it to them 3 times no solution at the end they said it happens in certain situations and that normal.![]()
Do you have a video of what it’s supposed to sound like?I was able to get a video because when this happens, it will happen subsequently if I don’t wait ten minutes between starts.
No, it sounds like that but through all of the speakers. I don't have that vehicle any longer.Do you have a video of what it’s supposed to sound like?
I took my 2020 Aviator to the dealer late last year for the same issue. They replaced the battery, under warranty, and it fixed the issue. The start/stop feature was also non functional at the time. It started working again after the battery replacement. Seems that some non safety systems stop functioning when a low battery is detected by the vehicle.I’ve taken mine in Twice for the chimes. 2 different dealerships. Still not fixed. They said they charged battery , reset a code.![]()
There is really nothing to fix. It happens when the battery charge gets low. I have posted about that before (posts 25 & 31). It happens to me as well and after charging up the battery, all is good again until the next time.I’ve taken mine in Twice for the chimes. 2 different dealerships. Still not fixed. They said they charged battery , reset a code.![]()
Well, in my 2020 Navigator, it had nothing to do with battery charge. A new battery was installed in mine at some point, and in short order, this occurred again and kept occurring up to the day I turned it back in to the dealer for my 2022.There is really nothing to fix. It happens when the battery charge gets low. I have posted about that before. It happens to me as well and after charging up the battery, all is good again until the next time.
