Deep Sleep Mode.
Minimina08
My Corsair is in constant deep sleep mode. Had it serviced no issues found. After talking with dealership and Lincoln it seems I don't drive enough? Suggested option is trickle down charger. I don't want a car you have to plug in. I am upset with this issue. Any one have any other suggestions. I feel I should have been told this since I don't put many miles on my vehicle. I love the Corsair, but now what do I do?
You should be able to "pull down" in the app to refresh the location. Or, depending on your device, completely close out of and reopen the app to refresh the location.
Also, under the Account tab is a tab for help. You can call that number or text chat with the Lincoln Way app support folks.
I'll call them, I've tried the things suggested and read that others had success with calling. I appreciate your time and suggestions.
Thank you so much for your kind explanation. Today I'm learning a lot from the forum and reading the owners manual. I take ownership for my "lock out" and this is a lessoned learned. I will not let my fob in the car in the future, especially knowing how easy a break-in can happen. I had a false sense of added security with all the alarm and security features the Aviator offers. After seeing how quick and slick it was "broke into" my fob will be with me always.
Yes, my Aviator started right up, no jump needed. I don't know if the battery is the original but I'll find out tomorrow. Conveniently, I have an appointment scheduled for the GPS / navigation system as it's not functioning with accuracy.
It makes complete sense that there's a sleep mode to preserve the battery. The technology amazes me.
Maybe you can answer another question, this one pertaining to the Lincoln Way App; (should it be a separate post)
Do you know how to get the location updated for my vehicle in the app? It hasn't updated it's location since Feb 8 but says up to date as of a few minutes ago. I did a remote scheduled start. It started, ran and shut off. I'm thinking it may have something to do with the navigation GPS, like I said is being serviced tomorrow. I hope to get answers then but in the meantime...
Thanks for your knowledgeable and kind feedback.
Hi Tracey. You are very welcome, and thank you for your kind words! 🤗
To answer your LincolnWay location question: Yes, it could be due to your GPS/Navigation system issues.
However, try this...Open your LincolnWay app and click on the address to go to the Location map. Or get to the Location map however you normally do. Then click on the compass icon in the lower left (EDIT- Sorry, lower right...lol) to update your location.
I have noticed a few times lately that my vehicle location would not automatically update until I perform that little dance...Even after I perform the pull-down update process to the overall LincolnWay app. Not often, but a few times.
Also, thanks for thinking of others and wondering if this should be a separate thread. Perhaps if you do have more questions about the LincolnWay app, vehicle location etc., it would be better if we discuss it in a new thread.
Hi Tracey. Okay great! I was not sure if you were aware of the Lincoln Complementary Roadside Service benefit, since I did not see you mention it.
Good luck. 🍻
Hi Tracey. There are several things going on here, so I will try to cover some of them in as brief a manner as possible. First, a little more detail would be helpful. For example, did the vehicle start up normally with the fob, once you gained access to the vehicle, or did it need a jump start?
Next...If your battery died or lost substantial charge after only one week of sitting, then the odds are good that the battery is failing and needs replacement. Unless you are in an area where temperatures are in the below freezing range, since that can bring on Deep Sleep Mode more quickly. And Deep Sleep mode will be enabled after 14 days of no manual starts, no matter any other factors.
Is it still the factory battery? The factory battery in a 2020 model may be 3+ years old by now, and 3-4 years is the expected battery life in modern vehicles, due to their heavy reliance on electronics, computers and other electrical features which constantly draw batter power, even when the vehicle is sitting still, such as sensors, remote apps and other items.
Next...For several reasons, you are on the right track that not leaving the fob in the vehicle while away on vacation would be the best idea. First, the fob contains a key blade which would have allowed you to gain easy access to the vehicle without help from others, a slim-jim etc. Second, if a thief broke into your vehicle, the fob would allow them to easily steal it.
Next...Contrary to the misunderstanding many owners seem to have, Deep Sleep Mode has a purpose. That purpose it to shut off accessory/ancillary functions which sap battery power, when the Battery Management System senses the battery is getting low on charge, in order to allow the vehicle to be started when necessary. In the past, all those functions would keep sapping battery charge, and the battery would die even quicker.
Deep Sleep mode allows the Battery Management System to extend the time period that the battery will keep starting power.
Next...When in Deep Sleep Mode, the LincolnWay app remote functions (remote start/lock/unlock etc.) will not work until the vehicle is started manually again. Manually meaning sitting in the vehicle with the keyfob and pressing the Start button. Keep in mind that also means driving the vehicle long enough to recharge the battery (i.e. generally ~20+ minutes at speed), since only starting it will not charge the battery, and simply leave us in the same situation as before.
Next...For the most detailed explanations, the best course of action would be to read the Owners Manual explanation of what "Deep Sleep Mode" is, when it occurs, what is does etc.
Odds are everything is working properly in your Aviator, and it simply needs a new battery. However, if anything still seems to be working improperly, then yes, schedule a service appointment with your Lincoln Dealer and explain the situation to them.
Hope I explained the basics in an understandable manner.
BBF,
So, if I understand you correctly, the only vehicles that should be having this sleep issue are those that are several years old and might have a battery that needs replacement.
As much as I have come to rely on your expertise, I hesitate to put my faith into that being the issue. I have read so many instances of Lincoln vehicles going into sleep mode during extended vacations and all the havoc that follows when owners return and can't get their cars started.
I am looking for a preventative only because I'm going to be in a similar situation in a few months where my vehicle will be left at a cruise port garage for a week.
Thanks, as always!
It worked, my location is current.
Much appreciated.
BBF,
Thanks, as always!
Hi NJRonbo. No, not at all and sorry if I was not clear.
A lot to unpack, so I will try to be brief. All that a Deep Sleep Mode notification signifies is that the BMS (Battery Management System) has determined that the current state of battery charge has reached a predetermined level considered to be on the lower side. Therefore, it turns off non-essential accessory and ancillary vehicle features, such as Welcome Lighting, certain LincolnWay app features, etc., in order to save sufficient battery charge. Otherwise, those features and/or their sensors keep sucking up battery charge, even when not actively being used.
Here are a few of the many reasons that a modern Lincoln vehicle will/may go into Deep Sleep Mode:
- Sitting unused/un-started for 14 days or more. This will occur no matter how strong or weak the battery may be.
- Sitting for extended periods in below freezing weather, even if used within 14 days. This may/will occur according to what the BMS determines the state of battery charge is, the current environment etc.
- A weak and/or failing battery..etc. etc. Again, this may/will occur according to what the BMS determines the current state of battery charge is, the current environment etc.
And there are various additional factors which may/will shorten those times, such as, but not limited to constantly using the LincolnWay app to check the vehicle (it activates certain vehicle systems and uses battery power every time we use it), approaching the vehicle repeatedly over time (when the vehicle is not being regularly driven), thus enabling the welcome lighting and using battery power, etc. etc.
The Owners Manual explains it in more detail.
There are many reasons that a vehicle can go into Deep Sleep Mode, and most of them are completely normal, have nothing to do with a vehicle problem or issue, and essentially are to maintain a sufficient battery charge for starting. However some of them can be a vehicle problem or issue.
In a properly operating vehicle, the main thing we all need to understand is that the "Deep Sleep Mode" notification is not a bad thing. It is simply telling us that the Battery Management System has determined the state of battery charge is getting lower. And therefore the BMS is turning off non-essential systems, i.e. the ones I mentioned above (which can use battery power even when seemingly inactive to us), in order to ensure the battery maintains a sufficient charge to start the vehicle, for as long a period as possible.
In the old days, the battery would have simply died. Now the BMS disables non-essential systems to help protect us. It is a good thing, which in many cases is not correctly understood.
Now with all of that being said, to be clear again: There are problems and issues which can cause a "Deep Sleep Mode" notification to be activated quicker than designed/optimal. In those cases, it can be due to the aforementioned failing battery, or any of dozens of various types of system problems (electrical shorts, electrical/electronic systems not shutting down properly etc.), therefore causing parasitic battery drains. And those issues do need to be properly diagnosed and corrected by our Lincoln Dealer.
Hope that makes what I was attempting to state clearer. If not, feel free to ask any questions you may have. 🤗
Good luck. 🍻
I for one would like to get a little shout out to bbf2530, he is a wealth of knowledge and always shares.
Hi ob. Thank you also for the kind words! They are truly appreciated! 🤗
Good luck! 🍻
BBF,
Thanks, as always!
Hi NJRonbo. I just realized my previous long response to you (which was supposed to be brief...lol), may not have directly addressed your specific concern.
While we obviously can not take all of the previously mentioned variables into consideration in your specific situation, but assuming a properly operating vehicle with a properly charged and operating battery, you should have no issues leaving your vehicle for one week.
BBF,
As always, you provide insightful, valuable information.
Just to be on the safe side, would it be a good idea to use a trickle charger (I have one) to fully charge my battery prior to my trip where I will be leaving the vehicle for a week?
And the trickle charger would go in the front battery -- not the one in the cargo area, correct?
BBF,
Hi NJRonbo. My opinion: If your vehicle is regularly driven now, and the battery is healthy, and/or you have a longer drive to the airport which would fully charge the battery anyway (and a healthy battery), it really would not be necessary for a one week absence.
That being said, it certainly would not hurt, if you are concerned about it.
Concerning whether to connect a trickle charger to the under-hood battery, or cargo area battery, or some alternate connection area? I do not have the Owners Manual handy for your vehicle. So it would be my recommendation to check the Index under "Battery" or "Jump Starting"/similar phrases, in order to see what the specific jump start/trickle charger instructions and the correct place to hook it up.
Alternately, I am sure another member with a Corsair GT has looked it up and will be able to jump in with that information.
Hope you have a nice trip and good luck!
Hi jdaniel. There is no "fix' needed. Nothing is broken. If a vehicle is not driven for 14 days, "Deep Sleep Mode" is activated to help save the battery from going dead. It simply shuts down certain ancillary features, such as the ability to check vehicle location, tire pressures/oil life etc. via LincolnWay app. Would owners prefer the battery dies, just so they can check vehicle location, oil life/tire pressure on their phone while they are away? Would coming back to a dead battery be better?
Unfortunately, many owners do not fully understand what "Deep Sleep Mode" actually is. In most cases, all deep sleep mode does is save your battery from going dead when the vehicle is not used for a long period of time.
Other than that, there are no important features lost until we can get out to our vehicle and start it.
Some owners don't seem to understand that our vehicles going into "Deep Sleep Mode" is not a defect or flaw. It is a battery saving feature. For vehicles with both healthy and weak batteries.
My 2021 Corsair goes into deep sleep mode daily and is driven daily. The only exception was a snow storm. Battery died when car sat for only 2 days. I've driven around all day, then come home and within an hour received a deep sleep mode notification. This is clearly not owner error, it is a defect that seems to be quite common.
I just happened to visit the Corsair Facebook page and yet another complaint about someone's GT going into a deep sleep and unable to be started.
And worse yet, it's a 2022 vehicle so it's not an issue of a bad battery.
I am going to make an effort to contact someone high up the ladder about this issue. It's one thing for Deep Sleep to protect the electronic power draw, but another for rendering owner vehicles utterly dead because the functionality goes too far.
I'll let you know if I get a response from Lincoln.
Hi Phantom and welcome to the Lincoln Forums. No one is inferring or claiming this is always "owner error". And we have covered all the possibilities in this thread, including quite a few of the possible vehicle malfunctions.
In your case and by your desription, it is entirely possible your battery is failing (yes, it can even happen with brand new batteries), or there is some sort of parasitic drain in your vehicle which needs to be diagnosed and corrected.
So to help us troubleshoot: Out of curiosity, did you purchase your 2021 Corsair new or used? If used, how long have you owned your Corsair? And when did this issue begin to occur? If you have owned your Corsair for some time but the issue has only relatively recently begun to occur, then it is most likely a failing battery. Have you had the battery tested by a Lincoln Dealer (or even a Ford Dealer)? If not, that is the first thing that needs to be done.
Your 2021 is still within the 4 year/50,000 mile new Vehicle Warranty, correct? If yes, call and set up a service appointment to have your battery and vehicle checked. Even new batteries can fail prematurely.
And if it dies again while at home or out, have Lincoln Complementary Roadside Assistance send out help. They can usually determine if the battery is weak/failing/has a dead cell or cells etc. Then you have the diagnosis when you bring it in for service.
Either way, the correct way to address this is have your vehicle properly diagnosed and fixed by Lincoln/Ford.
It's strange, I parked my 2021 Nautilus at the airport for about 2 weeks while we were on a trip to Scotland. Our flight left from Boston, so the drive from our house in Connecticut was 110 or so miles, plenty to top off the battery charge. 10 days in, I got a notification on my phone that the car had gone into deep sleep mode. I was kinda worried. I thought about doing a remote start, but being so far away, I didn't want to chance it if something was to go wrong. When we returned, though, I was able to unlock the doors and the car started right up.
The problems people are having with deep sleep mode seem to be a defect in the system. The GT models seem to have more problems, which isn't too much of a surprise given all the electrical infrastructure in those cars.
Hi NJRonbo. Even brand new batteries can fail, and only having the battery properly load tested (i.e. not a quickie battery meter test at AutoZone etc.) can diagnose and determine that. A proper battery load test takes several hours to perform.
Therefore, no one can claim it is not a dead battery...Or that it is a dead battery, until the vehicle and battery undergo a proper battery load test.
To try and explain again...It is not "Deep Sleep Mode that is causing a vehicle not to start.
The vehicle will not start because the battery has become low on charge for one reason or another. A vehicle going into "Deep Sleep Mode" is only a warning that the battery charge had dropped low enough to have the BMS invoke Deep Sleep Mode in an attempt to prolong battery life as long as possible.
In the old days, we might get a battery light warning right before our battery dies. And in most cases, no warning at all. Just a suddennly dead battery. Now, the BMS will determine that the battery charge is low and turn off unnecessary electrical features, such as Welcome Lighting, LincolnWay app remote features etc. It is not a bad thing, it is a good thing.
So while some may think it is arguing semantics, it actually is not.
Therefore, the issue is not "Deep Sleep Mode" itself, or complaining about Deep Sleep Mode. The issue is knowing how our vehicles operate and determining why Deep Sleep Mode is being activated. If our vehicle does begin to go into Deep Sleep Mode for reasons other than the 14 day no drive, or extended below freezing temperatures, or prolonged not being driven much/for much distance etc, then it is time to take our vehicle in to have the underlying cause determined.
And in an effort to help you, that is pretty much what you will be told by whoever, you speak to "high up the ladder" on this. After all the initial discussion, they will tell you to make an appointment to have your vehicle checked. In reality, that is all they can do. You will not be informing them of anything they don't already know. Sometimes batteries die. And in other cases, sometimes vehicles have a defect. And in some cases, vehicles simply are not driven enough to keep the battery charged up. All those possibilities can wind up with a "Deep Sleep Mode" warning.
I guess the short story is...If our vehicle is going into Deep Sleep Mode repeatedly, when we think it should not be, then make a service appointment to have it checked, instead of everyone futilely pondering and debating what might be the problem. There are simply to many possibilities for it to be determined blindly over the Internet.
I hope you understand that I am only trying to help, and am not trying to discourage you from doing what you feel is necessary, only trying to put this into some kind of logical context.
And in all effort to help you, that is pretty much what you will be told by whoever, you speak to "high up the ladder" on this. After all the initial discussion, they will tell you to make an appointment to have your vehicle checked. In reality, that is all they can do. You will not be informing them of anything they don't already know. Sometimes batteries die. And in other cases, sometimes vehicles have a defect. And in some cases, vehicles simply are not driven enough to keep the battery charged up. All those possibilities can wind up with a "Deep Sleep Mode" warning.
I guess the short story is...If our vehicle is going into Deep Sleep Mode repeatedly, when we think it should not be, then make a service appointment to have it checked, instead of everyone futilely pondering and debating what might be the problem. There are simply to many possiblities for it to be determined blindly over the Internet.
No, bbf, I certainly realize you are trying to help, and as always, you do so in a very in-depth and respectful manner.
This is at the top of my list of things that keep me up at night.
And, while I realize the importance of DEEP SLEEP, it just seems to me based on the number of dead vehicles being reported, that the software could be adjusted so that those who have new vehicles with fresh batteries are not experiencing issues. And, there are reports from people with new vehicles who have experienced DEEP SLEEP anywhere between the vehicle not being in use for a week to just overnight.
But, yes, there could be other variables concerning how much the car is driven or even driven in EV mode only (which is usually how I drive). To return from vacation to a dead vehicle is a scary scenario and it concerns me greatly that the chances of it happening are actually rather high and that perhaps Lincoln could have put more effort into educating its drivers on how to avoid it from happening. I mean, is there anything even in the manual about DEEP SLEEP prevention and optimal driving habits? It doesn't seem like anybody knows how to prevent it.
So, that is the reason for taking it up the ladder, if indeed it will do anything.
@heywardjr, if you are reading this, did you post a photo anywhere of how to hook up the trickle charger to the battery? I just opened up the hood of the vehicle to connect mine and I can't even recognize where the battery is located. I think it's under something.
@HeywoodJR, if you are reading this, did you post a photo anywhere of how to hook up the trickle charger to the battery? I just opened up the hood of the vehicle to connect mine and I can't even recognize where the battery is located. I think it's under something.
Hi NJRonbo. I think there is still a disconnect as to what "Deep Sleep Mode" is and why it occurs. And I'll take the hit for perhaps not explaining it clearly enough. First, it may help to realize it needs to be looked at and understood as a notification, not a warning.
My vehicle has gone into Deep Sleep Mode twice this winter, when the temperatures were below freezing and I had not driven for perhaps a week or more. In addition, when I do drive lately it is mostly short trips to the grocery store (~1/2 mile away) etc. So in my current case, I know it is because I am not driving anywhere near the frequency and/or distance I used to, pre-pandemic. And that is the case for many people. I am not saying all, but many. Such less frequent driving, as in my case, may/will lead to Deep Sleep Mode being activated more frequently.
On the other hand, when my vehicle was just over ~1 year old, I got my first of a series of repeated "Deep Sleep Mode" notifications, again, during a long cold winter. I took out my Owners Manual (or used the PDF version ;) ), looked it up, and realized in my case, my vehicle was going into "Deep Sleep Mode" too quickly, so it seemed the battery may be failing. I made a service appointment, they checked my vehicle and determined it was a failing battery. Battery replaced, all fixed. No worries, no Internet debates or other issues.
In my case, "Deep Sleep Mode" probably kept the battery from dying on me, and also notified me of a failing battery so I could have it checked and replaced before it left me stranded somewhere.
Also in my case, since this battery is now ~3+ years old, "Deep Sleep Mode" being activated a few times this winter also tells me that my battery may be getting weak at this point, so I can keep an eye on it.
This is why I look at "Deep Sleep Mode" as an asset, not a problem.
And yes, I realize my case is my case, not yours or anyone else's. This is why we all need to understand what Deep Sleep Mode is, take our personal driving habits and environment into consideration, and then simply decide is it normal for my situation or should I make a service appointment. It is simply my opinion that the information is now out here and known, so all of us continually debating it, instead of simply making a decision and an appointment for service is sort of an exercise in futility.
So my thoughts/opinion: First, we all need to stop complaining about "Deep Sleep Mode" being activated. Deep Sleep Mode is not a Check Engine light or a DTC code. Those are telling us there is a fault in the vehicle. Deep Sleep Mode is a vehicle system service that helps avoid a dead battery, not cause one.
In other words, the issue is not Deep Sleep Mode itself, the issue is determining why it is being activated by the BMS. What needs to be determined is whether it is normal in a particular situation, or is it a battery/electrical issue.
The fact that Deep Sleep Mode is being activated does not cause a dead battery, it helps avoid a dead battery. Therefore, the concern should be why is it being activated on my/your vehicle.
And Deep Sleep Mode does not mean the battery is dead and won't start the vehicle. It only means that the BMS has disabled unnecessary electrical draws on the battery in a sitting vehicle, i.e. what has been described previously. Think of it as a sophisticated and proactive battery charge warning light system. It helps avoid a dead battery.
And unless the description of Deep Sleep Mode has been omitted lately, the Owners Manual actually does explain it pretty well.
Either way, in addition, here are some easily researched explanations which can be found by Googling "Ford Deep Sleep Mode":
And I also included an attachment below.
So...just a few of the possible causes are:
- Deep sleep mode will automatically be activated once the vehicle has sat unused for 14 days.
- It will automatically be activated in sub-freezing temperatures after a set number of days. Far less than 14.
This is done to prolong battery life.
In addition, it needs to be kept in mind that any combination of those factors, along with a weaker or failing battery, can lead to Deep Sleep Mode being activated sooner than expected.
And in addition to the additions ;): I am not discounting or dismissing the possibility that others may have an electrical/electronic or other issue which needs to be diagnosed and corrected. There is always the distinct and ever present possibility that a vehicle may have some sort of electrical and/or electronic fault which is causing a parasitic draw. This is why a vehicle owner needs to read the explanation of Deep Sleep Mode in their Owners Manual, take all the information we have already provided, then decide if their particular situation is normal, or if it needs Dealer attention and service. And if it needs attention, then make a service appointment.
Instead of all of this hand wringing (not referring to you or anyone in particular), it simply means that if our vehicle begins to go into Deep Sleep Mode sooner and/or more often than it should, in a regularly driven vehicle, then it is time to make a service appointment to have the battery and/or underlying vehicle electrical/electronic systems checked for any faults, parasitic draws, etc.
Jokingly, I think some/many of us (including me;):ROFLMAO:) have too much time on our hands nowadays. If we didn't, we wouldn't be on here so much and would have less worries. 🙃😉
And of course, I can't cover every possible situation and contingency, such as the fact that some of us may have already had our vehicle in for service for this problem, but the diagnosis was that they could find nothing wrong, but there is still something wrong. I understand these things happen. However, the only answer and possible solution is still...make another service appointment until they get it right. Or open a Lemon law case against them.
Sorry for the repetitiveness, but I did not go back to proofread...I think I need a nap now. 🤓
I hope everyone can decide what is normal for their particular vehicle and situation and enjoy their vehicles as much as possible.
And again, I mean none of this as an insult to anyone. It is simply an effort to offer the best advice, and try and help in the best way I see possible.
Good luck. 🍻
This is so easy to address with a cheap battery trickle charger. I use it every couple of weeks to check the battery and I always notice battery level low but after the charger does its magic all is well. I never had had the error message since day one of ownership last year on my 22 GT. It's very easy to attach the battery charger wires to the battery located under the extra tire located under the back area. I run the connector there and charge up. Easily addressed. I had to do this on my 2016 Ford Fusion Hybrid as well as 2008 Ford Sport Trac. I work at home and rarely travel that much so the battery gets drawn down due to key fobs nearby, alarm system active, 3rd party cameras from the rear, CD player in the glove box, etc.
