mdnavigator
- Jun 9, 2025
- 2025 Navigator L
I've had my 2025 Navigator L for almost 2 months exactly (purchased April 10, 2025). Overall love it, but have had several glitches / issues and thought it might be helpful for us all to list these out as I expect many of us will experience the same problems! So far...
I'll add to this list if I learn more on any of these or if new issues pop up. Admittedly it is a bit annoying to have to make sure I have a socket set in the car at all times and have to make my wife comfortable with disconnecting the battery since you never know if these issues are going to pop up during a trip.... Shouldn't have that lack of confidence in a vehicle, especially at this cost. And yes I know, new model so I am one of the guinea pigs...
- Heat / AC controls went out - I couldn't adjust the heat/air, heated/cooled seats, etc. The vents were blowing hot air and no matter what I tried, I couldn't get it to stop or switch. I tried powering off the car, leaving it off for >1 hour, using voice controls, etc. but it just kept blowing hot air.
- I got this to work by disconnecting the battery. After taking the cable off one terminal, I waited about 30 seconds, reconnected it, and the car went back to operating normally. Only has happened one time so far.
- Front passenger massaging seat - randomly (and fairly often) the front passenger seat massaging seat will not start. It looks like it is turned on when you press the button or go into the option from the screen, but it is just frozen. Have only noticed this on the front passenger side, not drivers side
- I have not found a solution for this. It will usually start working on its own eventually.. not sure how long it takes, probably 5 minutes or so...
- Rear liftgate will not open - the liftgate won't open using any of the buttons (in the front of the car, the button on the liftgate, or the remote). When I press the button at the front of the car, it says the liftgate is ajar (it isn't). It makes the sounds as if it is going to open, but just remains shut.
- This is a new one today and I haven't had a chance to investigate further yet. I'll probably try disconnecting the battery and see if that resets everything.
- Map on top dash would not come up / BlueCruise would not work on interstate - I couldn't get the BlueCruise option to come up on a stretch of interstate where I've used it several times. I also couldn't get the map to display on the top screen even with the option enabled.
- I had installed Waze through the google play store. This was the first time I tried using it directly through the vehicle (vs through Apple CarPlay). It seems like that somehow messed up the vehicle map/bluecruise, because after I exited Waze everything started working fine again
