angore
 - Apr 3, 2024
- Location
 - Triangle area. North Carolina
 - 2024 Nautilus Premier Hybrid (Sheila)
We’re having the same problem with our Nautilus bought late June, they replaced battery on July 9th. Once again our battery is nearly drained, it started this morning but all information is dark. FrustratedI recently purchased a 2024 Lincoln Nautilis the dealer told me I was the first one in the state of Florida to take possession of the car. Within a few days they called me back to update the software for no particular reason and then within a week of that my battery went dead. I took it in for service, and it went dead again, I took it in for service another time and it continued to drain after they replaced it with a brand new battery now they’re trying to load software to monitor what’s happening to the car and the car won’t accept the software they’re trying to download into my new vehicle my car is only six weeks old I haven’t been able to drive it for three weeks. Has anybody else been having similar software and battery issues?
I’ve encountered the weather app not updating once. It fixed itself the next time I started the car without the need to reboot.The weather app was not updating yesterday so seeing if that goes away. Yes, I rebooted.
I also had a phone connection issue but that may have been my fault (phone BT) but got it working.
When had the Schumacher SC1281 indicated it was at 100%?After the complete no-start and call for roadside assistance that I posted about last week, I am now worried this car will leave me stranded. As the NOCO Boost GB40 is not strong enough to start a 80 Ah/800 CCA battery that is "too low," I purchased a Schumacher SC1281. Its advantage is that is relies on your home's 110V circuit rather than a small built-in lithium-ion battery. My concern is magnified that after sitting overnight and hooking up the Schumacher, it indicated the battery was at 25%. I could trickle charge it at 2-5 amps or boost charge at 30 amps. After less than 10 minutes in the boost mode the charger indicated it was at 100% and went automatically into maintenance mode. I didn't drive it since Sunday. This morning, the battery is back to 35% and had to hook up the charger again.
Bad batteries are a real thing. Another major premium brand has regularly been replacing batteries (and their production is in Canada, doesn't have a trip from China).You're probably correct about needing a new battery -- after 6 months and 3,900 miles!
From what I have read, batteries depleting to a low state of charge around 25% to 50% will prematurely lead to battery failure. But really? On a brand-new car? Give me back my 2019.
They may have been damaged due to transit. Sitting waiting g to be shipped, improperly configured for ship, improperly configured whole being prepped for rail, etc. If I take short trips my battery drops below 12v. For a hybrid, the HV battery could dump energy into the battery. I also wonder if the charge routine is low trying to to tweek mpg.You're probably correct about needing a new battery -- after 6 months and 3,900 miles!
The MKZ Hybrid battery would use it's power to charge the small battery if it needed it. Doesn't seem to be the case with the Nautilus Hybrid as it really does need additional charging monthly.They may have been damaged due to transit. Sitting waiting g to be shipped, improperly configured for ship, improperly configured whole being prepped for rail, etc. If I take short trips my battery drops below 12v. For a hybrid, the HV battery could dump energy into the battery. I also wonder if the charge routine is low trying to to tweek mpg.
Nobody has said it is only bad batteries.Anyone had their BCM reprogrammed? Did the trick on my Navigator last year when I was sure I needed a new battery. Factory battery running strong almost 2 1/2 years later from new.
But hey, must just be bad batteries.
I hear ya. Just asking.Nobody has said it is only bad batteries.
There is one unintended parasitic drain SW update (VDM) available at dealers now, and a second unintended battery drain SW update related to the driver monitor camera was put on hold as a dealer install (not sure why, what issue they ran into). Both of those updates are "reprogramming", of the particular modules where Lincoln has found bugs, are due for a wider release as part of a Q3 software update (meaning sometime by the end of September).
Nobody knows what other software updates for battery drain are being worked, we only find out about them when an SSM is released. Maybe there's a BCM one coming, though there are many individual modules in the vehicle (multiple little computers). The '24 Nautilus "BCM" itself is actually more than one module, in different locations, from chatting with Haz and looking at diagrams he had posted in a different forum.
We got it started after some angst. They're going to swap the loaner for another loaner for us.Irony. We've had our Reserve 2 in for the past 9 days for a few things that needed fixing, including a new battery. The loaner they gave us appears to be a Reserve 2 also, but the gas model (and Jet package).
This morning my wife went in to start the Nautilus and the battery is dead. It did manage to click the starter on the first attempt, but is completely dead now.![]()
