2024 Lincoln Navigator tire problems
  • Thread starter Thread starter G-488157
  • Start date Start date
I can't imagine "unplugging" the shock absorbers would work without wreaking havoc to the vehicle in terms of warnings and whatever system defaults may be in place.
For those who may not understand the working theory behind these types of shock absorbers, here is an AI clip...
Magnetic fluid shock absorbers, also known as magnetorheological dampers, use a special fluid that changes its viscosity in response to a magnetic field. When an electric current is applied, the magnetic particles in the fluid align, thickening it and allowing the shock absorber to adjust its stiffness almost instantly, improving ride comfort and handling.
Unplugging them in theory would likely leave the shock absorbers in a 'soft' state as the whole design theory relies on 'stiffening' the shocks on demand by magnetic force to the fluid inside the shock and depending upon the particular design, possibly affecting any variable valving inside the shock.
...Unplugging them in theory would likely leave the shock absorbers in a 'soft' state as the whole design theory relies on 'stiffening' the shocks on demand by magnetic force to the fluid inside the shock and depending upon the particular design, possibly affecting any variable valving inside the shock.
I don't think Navigators use magnetorheological dampers; GM vehicles (and whoever they licence them to) do though, and it's a superior design. I have two other vehicles with electronically adjustable shock absorbers, and in one of them disconnecting makes them soft, while in the other, conversely, stiff. So it's hard to say off the cuff.
In any case, vibration that appears at a certain speed is extremely unlikely to be related to shock absorbers. Testing that would be a wasted effort.
It would be great if there is a way to turn off/disable/stop the forward looking cameras or sensors from seeing the approaching road surface and therefore adjusting the ride (if that could cause the "vibration").
I cannot imagine how that system could cause vibration. But, if you insist, putting some masking tape over the camera should do the trick, I gather...
Have a 23 Navigator, was going crazy when i got it in April of 24. I've done all of the above Wheel alignment Etc. Its still a crap drive. Vibrates on any road and engine jerks upon lowering gears and slowing down. Seams like the dealers know about it and they just take it in and "address it" to make you feel good. Its a beautiful car its a shame it cant live up to its purpose "Luxury & Comfort". I learnt to live with it. Eyeing the Escalade next. Hope Lincoln actually reads these forums and addresses this.
I’ve tapped the cameras and no change was noticed on highway speed months ago. I removed Body control module fuse to see if that shuts down the whole system. To my surprise, the system keeps on operating normally with no fault codes and no change in the vibrations. Quite strange.
Interestingly body control module share common fuse with image processing module. There were no errors or problems with image processing at all with the fuse removed. Possible someone messed up the wiring, lol. That will be laughable if turns out that case.
To rule out transmission issue, I’ve had the vehicle run in Neutral at 70mph, no change was noticed.
The rough idling is definitely related to turning on the AC
my next target is the lug nuts, wheel bearing since every time I had independent road force balance, the pattern of vibration shifts from higher speeds to lower speeds and vice versa.
Can't buy a Navigator, can't buy an Escalade or Yukon with the 6.2 engine crankshaft failure, dont want an Expedition......
What a sorry state of affairs.
Planet Lincoln has had my car for a month and is trying to sell me on new tires, which I'm quite certain won't fix the issue. They are trying to blame it on my gravel roads. Been driving SUVs for 25 years (two previous Navs included: 20018 and 2021) on these roads and am beyond frustrated that's what they are blaming it on. Even claiming "we haven't heard of this." Really, because this thread alone has 5 Planet Lincoln customers on it. Has anyone moved forward with the Class Action Lawsuit? We would like more information on being included, if so.
You also have the wagoneer, armada, x7 and gls as options
GW only, but it looks like it's even worse than GM and Ford offerenings in terms of issues. Others don't really have cargo space with all three rows up, and that's a deal breaker for many (myself included).
I'm here. I posted yesterday.
I'm going back to an Escalade when the LemonLaw buy back goes through. It was a dream for 7 yrs. It got stolen and when they hot-wired my car, the electronics didn't work after that. I could've driven it another 150,000 miles. Lincoln lured me in with 0% financing. I won't be tricked again.
After the dealer having my truck for a month and replacing the rotors, pads, 2 front hubs, 2 of the tires for the second time, I had 2 vibrations instead of the 1 highway speed, seems they created another vibration from 40 mph and up so I put it up on some ramps and found the cloth panel underneath between the engine the transmission installed incorrectly and missing hardware causing it to create a wind drag when driving. After fixing/securing the panel the 40mph vibration went away and the highway vibration from 70 to 85mph was almost completely gone. So I figured doing 1 more professional roadforce balance would make this slight remaining vibration go away. Boy was I wrong because the tire shop did the balancing twice and got the lowest readings possibly on the roadforce balance but the vibration got worst and I knew they possibly rotated the wheels to different axles after balancing so I decided to put the left front wheel which had the higher balance reading back to the left rear and its still noticeable in the front but now the vibration increased in the rear seats. At this point I strongly feel that something is defective with these black 8 spoke oem rims. A close friend of mine that works for ford/lincoln dealership shop also told me that the dealerships that are dealing with these issues should have try replacing the driveshafts.
I agree. The splash guard does seem flimsy on just holding it out. I haven’t had a chance to lift it up and securing it. Another issue which have seemed to somehow made a difference is the rotors. Due to 2024 standing on the lot for extended period of time. There is layer of rust present over the rotors around the bolts where lug nuts go. I sanded that area down on two front tires and mounted the tires with torques wrench getting the specs down to 150 ft-lb. I think there are multiple areas of rust which need to be cleaned one at a time.
I’m not sure of the new rotors you got are still rusted ? Just a thought
For reference see this, this is not the actual picture but fairly representative, wish I taken actual picture.
... There is layer of rust present over the rotors around the bolts where lug nuts go. I sanded that area down on two front tires and mounted the tires with torques wrench ...
I do this on all my vehicles any time the wheels are off. I doubt the tech at the dealer does any more than possibly torque the lug nuts.
The new rotors are not rusted, also I went on a little trip this weekend and noticed that the vibration gets worst and better on certain highway sections on the 3 different highways I had to use to get to my destination. Only thing I can think of it must have something to do with the camera reading the road and telling the shocks what to do. Or possibly an imbalance in the engine somehow.
For what it's worth the vibration issues with my 2024 Navigator L has improved since the last dealer visit where they rotated the tires. Prior to the visit there was a noticeable difference at 75 mph and above. Afterwards there is some vibration at 80+ mph. Not really noticeable in day to day local driving but I had a fair amount of windshield time with a recent road trip to confirm my subjective opinion.
I even downloaded a vibration meter app on the phone to analyze it.
While somewhat difficult to accurately compare in real world driving, I did note readings averaging about 0.2 (m/s^2) at 70 and 75 mph while the average reading was 0.3 at 80 mph on the same type of pavement on straight level interstate driving. But even at 80-85 mph it was noticeably less than before at 70-75 mph.
Tomorrow I plan on using the spare tire to swap out each wheel and drive on the highway to see if the vibration changes. I have had the wheel balanced by multiple shops and sometimes its helped a little or got worst. I am actually down to one specific wheel that I rotated before and felt like the vibration hot worst in the back of the vehicle. So that will be the first wheel I swap out for the drive. Might just be one slightly defected rim thats causing this whole issue. There was already one guy in this forum that said it was just a bad rim that caused his issue.
