DonLew
- Oct 28, 2025
- 2024 Nautilus
Yes there is an option for the interior motion sensor to only ask if you want to set to on or off. There is an option to turn this question on or off as well. Plus there is an option to turn the motion sensor off on the screen. I assume from your statement "For safety purposes, I believe the Interior Motion Sensor default is to reset to ON upon each restart" also applies to this option as well.Hi DonLew. Don’t take this as the final word, and if I am mistaken, other members will certainly jump in:
If I recall correctly: For safety purposes, I believe the Interior Motion Sensor default is to reset to ON upon each restart. So it is not your choice of locking method.
There should be a programmable display option to have your vehicle ask if you want the Interior Motion Sensor set to ON or OFF, upon each vehicle shut off.
These features can vary by vehicle and model year, so I would recommend you check your Owners Manual for your particular vehicle.
Thanks, DonL
