2023 Navigator Glare Free Lighting Forscan
Sprint76
2023 Navigator
I have a Lightning and was able to enable the glare free lighting following the instructions here: Adaptive Head Lights - Coming to the US???
Since then I've been trying to enable it on our 2023 Navigator L which also has the LED Matrix headlights, and I finally have it working. If you haven't used them yet, they are a huge upgrade over the oversensitive auto high beams Lincoln has by default.
You'll need Forscan, a compatible adapter, and to follow the basic instructions found in that thread. These are the settings:
APIM:
7D0-03-01 4341 xxxx xxxx (this one may not be necessary as it's just changing the country code from US to CA)
7D0-09-01 x5xx x0xx xxxx
7D0-09-03 xxCx xxx4 xxxx
IPMA:
706-01-01 xxxx xxx9 xxxx
IPC:
720-01-01 xxx3 xxxx xxxx
720-02-01 xxAx xx5D xxxx
720-04-02 4341 xxxx (this one may not be necessary as it's just changing the country code from US to CA)
720-10-01 xx1x xxx3 xxxx
HCM:
734-01-02 xxxx x2xx xxxx
734-11-01 E8B5 xx
Anyone else have tried this?I have a 22 black label, I did this on my f150 and it’s good
APIM:
IPMA:
IPC:
HCM:
734-11-01 E8B5 xx
I also have a Lightning and 23 Nav L and I'm in the middle of enabling the glare-free headlights. Have you seen my wife?
Hi, is it also possible to reprogram anti-glare in the 2020 Navigator?
Would a 2024 Navigator use the same values?
Anyone know if this is still possible with a 2023 Navigator? With all the OTA updates wondering if not an option anymore. I have tried the settings twice now and even see Settings > Lighting: Enable "Glare-Free High Beams" as a toggle but it doesn't appear to do anything but break all auto functions. Test drove twice after trying as built method and easy methods above 35 mph to verify.
Livinitup's spreadsheet has the following:
"Glare Free Menu (replaces Auto High Beam in APIM)
Note: do all the changes to the right except but choose the appropriate selection for 734-01-04
Note: reported that this only works on 2021-22 now"
I know it's F150 based but all the same settings, modules apply.
Looking for any proof it's possible before I give up.
