2023 Navigator Glare Free Lighting Forscan
Sprint76
2023 Navigator
I have a Lightning and was able to enable the glare free lighting following the instructions here: Adaptive Head Lights - Coming to the US???
Since then I've been trying to enable it on our 2023 Navigator L which also has the LED Matrix headlights, and I finally have it working. If you haven't used them yet, they are a huge upgrade over the oversensitive auto high beams Lincoln has by default.
You'll need Forscan, a compatible adapter, and to follow the basic instructions found in that thread. These are the settings:
APIM:
7D0-03-01 4341 xxxx xxxx (this one may not be necessary as it's just changing the country code from US to CA)
7D0-09-01 x5xx x0xx xxxx
7D0-09-03 xxCx xxx4 xxxx
IPMA:
706-01-01 xxxx xxx9 xxxx
IPC:
720-01-01 xxx3 xxxx xxxx
720-02-01 xxAx xx5D xxxx
720-04-02 4341 xxxx (this one may not be necessary as it's just changing the country code from US to CA)
720-10-01 xx1x xxx3 xxxx
HCM:
734-01-02 xxxx x2xx xxxx
734-11-01 E8B5 xx
Anyone else have tried this?I have a 22 black label, I did this on my f150 and it’s good
APIM:
IPMA:
IPC:
HCM:
734-11-01 E8B5 xx
I also have a Lightning and 23 Nav L and I'm in the middle of enabling the glare-free headlights. Have you seen my wife?
