I have a 1979 Lincoln Mark V and the steering coupler (aka Rag Joint) has completely deteriorated. The shop manual indicates that the entire U-Joint assembly must be removed to replace the steering coupler because rivets on the OEM part/setup must be drilled out. Unfortunately, the bolt that attaches the U-Joint assembly to a steering shaft is obstructed at the firewall. The connect seems to be 1 to 2 inches inset to the firewall opening and, although I can see it, I can't seem to get to it.
Does anyone have ideas? Image #1 shows the actual part. Image #2 provides a context to the setup.
