I wish I could find a picture of installation of mine. Unfortunately my Mark III is in Michigan and I am not.
Attached is the only picture of the trunk that I have. Taken in October 2022
I believe the lining is original. (No piping)
Not sure is the spare tire cover is original.
Notice the wing nut on the "J" hook is not threaded down. There are no more threads.
For a long time I could not get the jack based and hook installation correct.
Still not sure.
I believe my Mark III got hit in the rear. Such that the deck lid was replaced. And I believe I have a 1969 deck lid on my 1970 Mark III. There are no holes for the lettering on the deck lid which was correct for 1969. Model year 1970 & 1971 used lettering with pins and holes.
So, there are no letters on the deck lid of my Mark III either.
The remote deck lid motor was missing and the vacuum line & wire harness for deck lid light was stuck down to the left of the deck lid hinge area.
The deck lid illumination light was missing.
The optical fiber brake light monitor was cut at the tail light assemblies.
The jack instructions label, the "J" hook, tire iron and the spring and clamp for the jack were missing. (All have been replaced)
The jack base and hook were laying in the bottom of the trunk.
Not sure I have the correct "J" hook. As clamping that set of pieces to the spare tire are loose.
I have since purchased the correct vacuum motor for the remote release. (Ford used 3 different ones in that period)
Purchased and installed the correct deck lid illumination light.
Replaced the entire brake light monitor system
Connected the vacuum line and decklid electrical line. Used the correct wire loom clips to support the harness along the deck lid shown in the left side of the picture.
Also replaced the rear vent drains (subject of this thread) with the reproduction rubber drain hoses that are now over $150.
Note those drains and the factory drains have a one way drain valve in the end to keep dust from coming up into the rubber hose.
My vehicle was built to Federal standards and delivered an Ohio dealership and a customer that was an Ohio banker. So no evaporative tank venting.
I did a lot of research on the power antenna. (Not shown) It has been removed repaired and reinstalled.
Replaced the deck lid lock cover. (Not shown)
Replaced the trunk weatherstrip. Difficult to see in this picture. And rather inexpensive compared to other things.
Painted the jack hook and base a semi-gloss black after this picture was shot.
Sometimes it is about the details. Other times it is always about the details. Get the details right and others will look at it and remark how nice it looks. You will look at it and pick it apart. And sadly the LM Master Parts Catalog is not as detailed about the jack parts and some other pieces as I would like.
