Open Letter to Lincoln - How I'd Improve the Aviator
You've got it right! That's the decision I'm suggesting you revisit.
I'm not sure why I should revisit.
BTW, the steering wheel driver daxing camera is used only when BlueCruise is ON, not Active Lane Keeping.
Lincoln executives have been watching this community for years. They've also made improvements to their vehicles based upon what they've read here. They are listening to you.
As am Aviator driver, you should state exactly what you'd like to see enhanced, added, and/or omitted from your Lincoln Aviator.
The dynamic air suspension that lowers when you walk up to the car for aiding in easy entry and exit is perfect for my mobility challenged passenger ... however, it doesn't lower when we get home and put the car in park. So the easy exit part apparently only applies to the driver re: seat and steering wheel. Update the logic to include lowering on park or on ignition off, or even if we had to push a button on the screen or something. One of the big reasons for my purchase, and it only works for 50% of the issue ... the silly workaround are for me to get out, lock the door, walk away, then walk back up to get the car to "kneel" again.
Welcome to the Forum Terry. 👋
The Easy Entry/Exit feature is only for the driver's position. What you are talking about is the Easy Access Height feature which I see from your other post, only works for access and not for exit. I agree that having it work for both procedures makes more sense. Just for interest, have you tried opening the liftgate when you park to see if the Cargo Loading feature will lower the vehicle?
