Lincoln Premium Connectivity Expiring What will I lose?
Mine was supposed to expire yesterday but everything so far seems to still work. I don't use any of the Google voice commands and Connect via carplay almost 100% of the time. The weather widget and panoramic map is working as normal.
Yep, so was mine. But everything is still working today. I will purchase if and when it terminates though. I other like the remote start (too far away to use the fob at work) and phone as key feature is great. I leave my fobs in a faraday bag in my safe at home.
I guess we'll find out soon enough.
Took a trip. Google maps states it is offline now but saved maps work without traffic. I had issues with sirius xm and voice so rebooted and seemed to fix the issue. Play Store seems gone.
There was a link to get the service back and option to blank main map screen.
I had to go through the setup again to get phone to work in full android auto. Our cell is bad but in garage in Nauti it is non existent. Google on phone has never worked well in garage since it is cannot connect.
Mine expired. My Google Map still displays my current location. But if I try to navigate to a region that I have never driven the car, it says it can’t do that. It can only leverage the Google Maps that have already been downloaded to your car. There is no further downloading. I suspect your default upper map will stop working as you drive into new territory. If you use Apple Maps for navigation, then no issue. Except the upper map display may not be nice when not doing an active navigation.
So remote start by phone (and I guess scheduled starts) as well as phone as a key gone as well? Thanks!
I still see all those related options.
Still showing in the app and still working.
After the Lincoln connectivity disappeared, I learned that just because phone has connected via AA (icon on small screen), AA has not started completely until you select the AA icon on small screen. Doh! Until then one is in limbo land.
Voice will be in Lincoln mode until then for navigation (still will start trips on offline maps). In phone mode, the voice sometimes breaks up and sometimes gets the something is wrong or no connection feedback and this is now more obvious. I never heard that in Lincoln mode.
Strange! My AA connects without having to select the AA icon if it was used the last time.
When in AA, the center screen shows traffic on the map, but the panoramic screen no longer shows traffic.
Initiating calls and "send message" voice command still works from both the button and "Hey Google". The center screen will show a message saying "cannot connect" but the request goes thru. However, if the contact has multiple number, I have to select which number to call or send message to. This is the same in Lincoln mode or AA.
It connects but does not seem ready until i do the next step.
I can still ask Google to navigate somewhere. It uses offline maps.
I asked Siri to navigate somewhere and it failed saying it needed an internet connection to do so.
This is while running Car play. I can’t remember if I ever tried the same command while I had premium connectivity.
Yes, Google navigations will still work as long as you want to navigate somewhere that is in the offline maps already downloaded. But try to navigate to someplace well away from where you've been and it won't work. It does not have the entire US or North America downloaded. It also no longer offers you route alternatives to pick from, presumably because it uses the cloud to calculate that based on real-time data such as current traffic. It also no longer shows you real time data that could impact the navigation such as heavy traffic or police up ahead or something in the road.
Something must be wrong or have been wrong with your internet connection for Siri to fail like that. I've used CarPlay Maps (Apple Maps) several times since losing my connectivity package and it works just like before. CarPlay uses your phone's internet connectivity. Not the car's. So your phone didn't have a good signal probably. That is unless you pay for the AT&T wifi hotspot and had your phone connected to that. Then there might be an issue.
