The car lovers social network
Dance Music Discussion
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Advertise with us!
2024 Nautilus owner; curious; when do you get your oil change, when the car tells you or when it reaches a certain percentage? Mine is at 21% now, deciding if I should schedule appointment.
I did my wife's at 2499 miles, then again at 7062 miles (oil life said 31% at 7062 miles). I plan to do every 5K miles after this. I use the Ford FL2127 filter and Mobil 1 SUV & Truck 10W-30 which meets Ford specs. That Mobil 1 is supposed to have at least 30* - 40*F higher flash point to reduce coking on Turbo engines. Not sure if it will make a difference, but it makes you feel better! We use 100% Top Tier fuel but mostly regular 87. Currently plan to trade shortly before the 4 year warranty has expired which will likely be 30 - 35K miles due to all the issues Ford has with carbon build up on the EcoBoost engines.2024 Nautilus owner; curious; when do you get your oil change, when the car tells you or when it reaches a certain percentage? Mine is at 21% now, deciding if I should schedule appointment.
