2025 Nautilus - No Aux Input Via USB-A?
Very interesting. Can you tell any difference in the replacement from Samsung? Different formatting? I can't get any of my 4GB sticks formatted FAT32 to be recognized.
Have you tried a low-level format vs quick format? Have you tried MBR vs GPT? You can change that if you use the Disk Management utility.
All the flash drives I've tried have worked. As such, I've never had to experiment. I'm not sure what else could be your difficulty.
Has anyone found out how to make the music files on the USB stick play in the order you want them to? Play all seems to play them in alphabetical order by meta data song title. If you select album it only plays one album and does not continue to the next one.
I heard a while back it was alphabetical via filenames. But I can't confirm this. A suggestion was given to use the utility MP3TAG to set the order of files with a numeric prefix, but I honestly haven't explored this. Good luck.
There was no difference. Also, the first USB did work in my Nautilus, with time, it stopped working on occasion, then more and more. I'm so used to electronics never failing, but I think in this case the drive did fail.
No, If it was alphabetical by file name it would do what I want, since I have named all of my 4500 files Album name- Artist- track number- song name. If someone could tell me the playlist format and the playlist file format I could make a playlist that play songs in the order that I like.
I believe it works off of the ID3v2.3 tags, not the filenames. I generated a couple set of files to try testing, haven't gotten around to it yet (modifying the tag Track and Title tag fields on 3 copies of the same album mp3 files).
Yeah, I knew. But neither my wife nor I ever close these things on our vehicles. They might as well not exist. Not that we're messy. We're just utility-driven.
Form does follows function, iff the function is not impeded by form. How difficult was it to remove your glove box door?;)
I just knew someone would go there. It wasn't too bad, but everything kept falling out when my wife would peel tires trying to always be first racing from the stop lights. I had to put it back on. 😮‍💨
I've tried various different USB sticks - 2GB, 4GB, 256GB, all formatted FAT32, some completely reformatted, some with folder, some with drive name, etc. etc. etc. and the only ones that work are 2GB. I'm gonna chalk this one up to 2025 non-hybrid Nautilus software.
