You can check right on the back side of your Wheels. The office is molded right on the back side of the rim spokes. Wheel diameter , rim width and offset are all there. Remeber this is a new platform for the 24 Nautilus. C2 platform is the same for the 2019 and up Focus, 20 and up Escape, Maverick, Bronco Sport and Nautilus. I personally measured the hub bore. 71mm
Hi Lincoln 24. I was only asking my previous questions in order to help others with the question, and do not have a Nautilus.
Did you get that 70mm spec off your 2024 Nautilus wheels? Not all factory wheels have the specs stamped on them.
I tried researching before asking you my earlier questions, and could not come up with what I would consider to be definitive 2024 Nautilus wheel spec information. However, as an example, here is data on the 2020 Escape (only since you mention it, and the C2 platform, in your previous reply):
2020 Escape wheel offset - Google Search
And if I recall correctly, the previous generation Nautilus wheel offset was somewhere in the 40-44 mm range. And the last generation Focus (which you also mention) was also in that same general offset range. While I can certainly be incorrect, experience states such a large variance, to 70mm, would be highly unusual.
In addition, the center bore specs I find online state the center bore of the 2024 Nautilus is 63.4 mm. But again, I admit that information may be inaccurate. That’s why I was asking for some sort of official verification, one way or another.
Please understand I am not tying to argue. What I am trying to do is help provide the correct offset information. And experience tells me that a 70mm offset on a modern Lincoln/Ford CUV would be highly unusual.
I would only add that since it is a new model, I certainly realize that the information I/we find online is still incomplete and often confusing.
Hope that explains my reasons for asking if there are any official links you (or anyone else) may have access to and would be able to provide.
Again…information is scarce at this point, so I’m simply trying to make sure we provide the correct information.
