I finally got an ob2 in the mail and screenshotted all of the info, if possible, i would appreciate it if you would let me know if you see any problems as the cel keeps coming back. let me know if any other info is needed or missing, i did it with the car startedMy mistake, the line of dirt fooled me into thinking there was a separate washer present. Sorry.
Those are a lot of screen shots. The last one showing the single DTC that you have for P0430 is the original problem with insufficient oxygen removal between the 2 oxygen sensors for bank 2 (grille bank of cylinders). That would normally be a faulty CAT that cannot use up the oxygen to reduce emission level (excess gas or oil will destroy the CAT, or a faulty sensor which would could be the heated oxygen sensor since the HCAT is problematic in the I/M readiness screen. The rear oxygen sensor seems to have been cleared in the I/M readiness monitor. The heated O2 sensor is the first one in the exhaust manifold. Problems with the heated O2 sensor will give driveability issues.I finally got an ob2 in the mail and screenshotted all of the info, if possible, i would appreciate it if you would let me know if you see any problems as the cel keeps coming back. let me know if any other info is needed or missing, i did it with the car started
Thanks a lot. I spent half a day trying to learn this. So basically the cat most likely is faulty i assume? The car has been lagging in pickup, the bank 2 is near the front bumper to confirm?, at dealer about $337.Those are a lot of screen shots. The last one showing the single DTC that you have for P0430 is the original problem with insufficient oxygen removal between the 2 oxygen sensors for bank 2 (grille bank of cylinders). That would normally be a faulty CAT that cannot use up the oxygen to reduce emission level (excess gas or oil will destroy the CAT, or a faulty sensor which would could be the heated oxygen sensor since the HCAT is problematic in the I/M readiness screen. The rear oxygen sensor seems to have been cleared in the I/M readiness monitor. The heated O2 sensor is the first one in the exhaust manifold. Problems with the heated O2 sensor will give driveability issues.
The first screen shot (bottom of prior page 4 of this thread) shows the I/M readiness for a emission test, and it is not ready. You have a red DTC marker which is the P0430 and one Pd DTC which is a pending dtc that a problem was detected on one occasion but needs a confirmation on a second run of the same problem (an example would be inability to retain pressure in fuel tank for a leak test must occur on 2 successive runs, so first run with leak detected is a pending DTC).
The AIR is probably the secondary air injection into the CAT for quicker emission reduction, but not sure about your car since the air pump is old technology. More research on the 3.7 to figure that one out. The HCAT is the heated oxygen sensor probably for bank 2 since you have P0430 that applies to that problem.
Hope this helps you.
No not the CAT, the heated o2 sensor. The test said the CAT is ok. The HCAT is the heated oxygen sensor. You are correct on bank 2 being close to the bumper, since bank 1 is close to firewall.Thanks a lot. I spent half a day trying to learn this. So basically the cat most likely is faulty i assume? The car has been lagging in pickup, the bank 2 is near the front bumper to confirm?, at dealer about $337.
Oh nice, thats much more palatable, the o2 sensors are much cheaper, i will change both sensors in bank 2. And yes, i have the procedures printedNo not the CAT, the heated o2 sensor. The test said the CAT is ok. The HCAT is the heated oxygen sensor. You are correct on bank 2 being close to the bumper, since bank 1 is close to firewall.
The lagging in pickup would be a driveability issue related perhaps to the problem readings from the heated oxygen sensor. I think i already gave you the procedure to replace the sensor. Check that it was for your 3.7 engine.
Or a misfiring coil for which we have another sort of proof - very old spark plugs can damage coils.At 90K miles, this may be just a bad O2 sensor on bank two (easiest to get to and easy to replace). On my Cadillac and 88 BMW, the O2 sensors were failing around 80K miles (haven't owned anything with that many miles since). Worth a shot.
But, I still believe you have spitting injectors -- once upon a time you used to be able to put your finger on each and tell which had a different pulse width.
Another likely suspect is a dirty MAF sensor: since most of these Continentals are fairly new (I had only 23K on Bambi killer), not many of us have seen bad MAF sensors -- yet! Trying cleaning it with CRC MAF cleaner; also check the wiring at the sensor.
Yes a surprise to me too, but it looks like the MAP sensor is faulty. See if replacing that fixes anything. I would think a MAP sensor would cause a DTC. The after CAT oxygen sensor would be the next suspect.Hmmmm. Surprised no maf sensor. I will take a look at the map and replace it. Appreciate it. So i guess i shouldnt change the bank 2 o2s?
Ive prbbly put about a gallon of fuel injector cleaner over the past weeks; and everytime the check engine came off for a while; maybe it just is some dirty fuel injectorts.
the way its been driving, its like its sticky outta first gear and then it goes zoom.
Ill further check the coils and do the scanning graph whilst driving on saturday.
So the cars been running great, knock on wood, i didnt want to update and get unlucky w the cel popping back up. so last weekend all i did was clean the entire engine bay with soap and water, changed the cabin filter. The cel was gone 2 weeks ago on its own, than popped up couple days later, but last weekend it went away, then last weekend before the cleaning and cabin filter change, cel popped back up and car was sluggish.BTW, map sensor readings could be reviewed in real time through the engineering test menu - back arrow and OK button held together while starting up.
How's it going?
3.5L Ecoboost not 3.7Yes 3.7. Alright, i guess i will change the o2 before touching the cats, bc i cant believe theyd go bad at this mileage, everything else works perfect
