Turque help
Jettadriver
Anyone know the turque specs for the valve covers, and head bolts, and tighting sequence, on the ford v8 4.6 in a continental??
Attached are the specs for the 4.6 4V engine in the 1995 Continental. Torque specs are near the end. The 13 Cylinder head bolts do not have a torque spec, so they are probably the "Torque to Yeild" spec, where the bolt must be new and torqued to a set number and then turned a certain number of degrees. You have to follow Ford specific procedure.
