TownCars1
Senior Member
I am noticing more and more that my transmission is keeping itself in a very low gear at the wrong times. It was a rare occurrence when I first got the car a few months ago, but it's getting much more common.
Most of the time when I start off, the transmission shifts normally between 2K and 3K RPM depending on how I heavy I am with the accelerator. But more and more, it's shifting and staying in 3rd or overdrive, and not letting the engine get over 1K RPM. It's still very driveable, but it has the acceleration of an early Geo Metro. I don't notice the engine bogging, it's just in the wrong gear.
Also, when cruising on the surface roads or freeway, it won't always downshift as I give it more gas unless I turn off overdrive, so acceleration is also pathetic during those times.
The car now has 108K miles. The transmission level is good, and I bought a new filter with gaskets in prep to change the fluid -- so that's already on the table.
Anything else I should be looking at with these symptoms?
