The 2003 models and above have dual blend door actuators so that the driver and front passenger have separate temperature control. The rear seat passengers receive air through the rear passenger duct from the driver side BDA and temperature setting. Both BDA's are located in the center stack and accessible without removing the dash. Attached are the procedures to replace the LH (driver side) temperature blend door actuator (BDA) and the RH (passenger side) temperature blend door actuator (BDA).
Town,
I posted the below on the main forum, but figured this was probably a better location as it is related.
Thank You in Advance.
V/r
Michael
2007 Lincoln Town Car Blend Door Actuator Replac. led to No Windows/Sunroof/Radio/Shift from Park
HELP!
I followed the instructions provided in this forum to replace the blend door actuator on the drivers side.
When reconnecting the Lighting Control Module (LCM) plugs, there were some sparks during the last small square plug insertion (near steering column) and the car alarm, horn, etc. started going off. Grabbed keys and hit buttons attempting to shut off alarm - finally it shut off. Do not remember if keys were in the ignition (possible) while reinstalling LCM.
Then replaced the passenger blend door actuator - no issues.
Now power windows, moon roof, mirrors, radio don't work and it will not shift out of park (but will start).
Checked fuses and only finding was the blown 20A cigar lighter/OBDII fuse. Replaced. I believe this was a pre-existing problem.
Checked circuit breaker CB602 (Delayed accessory relay for windows, moon roof, audio and navigation system) - still have continuity.
Any help would be greatly appreciated!
