Wizzer01
Upgraded the Sync 2 to Sync 3 a few days ago. It's pretty awesome! Kinda like driving a new car. If anyone has any questions, I'll try to answer them.
How do you remove the dash to get the screen out I'm in the process of doing the upgrade myselfUpgraded the Sync 2 to Sync 3 a few days ago. It's pretty awesome! Kinda like driving a new car. If anyone has any questions, I'll try to answer them.
I would like to do it but I changed my mind when they said you would have to install a new gps antenna and that the usb and video inputs in the arm reset would not work with the sync 3 is this trueSync 3 swapped never mind the info ... but if anyone wants info I have it
I would like the info.....have a 2014 with nav....do i need a new screen and everything? email gucsm2@comcast.netI would like to do it but I changed my mind when they said you would have to install a new gps antenna and that the usb and video inputs in the arm reset would not work with the sync 3 is this true
1. Remove the wood trim (long piece and small piece)
2. Loosen side panels on center console (these don’t have to come all the way off just from foot well to seats)
3. Remove shifter cover (open console storage bin and shifter to neutral pull up the 6 clips 3 on each side unplug the 2 electrical connections)
4. Remove the screws on the passenger side air bag cover(open the glove box and remove the panel ** you can squeeze this panel out form behind the glove box inner panel**)
5. Remove the drivers side panel (you have to drop the lower panel under the steering wheel then screws pull panel straight out)
6. Remove the heater controls (screws and clips at the top unplug the electrical connection)
7. Remove the screen bezel/ heater vents (screws and clips)
Then you at your screen (screws and electrical connections)
** NOTE ** you must reprogram the sync 3 unit with forscan to work properly.
Mine did it automatically, kind of like a cell phone update.How do you remove the dash to get the screen out I'm in the process of doing the upgrade myself
How much did that cost?Upgraded the Sync 2 to Sync 3 a few days ago. It's pretty awesome! Kinda like driving a new car. If anyone has any questions, I'll try to answer them.
What year do you have?Mine did it automatically, kind of like a cell phone update.
