Tonja Acker-Richards
- Jul 18, 2019
Our sun roof sounds super squeaky. Do you think wd40 could safely be applied to tracks? My concern is the rubber gaskets.
Hi Tonja. Is your Nautilus still within the 4 year/50,000 mile Bumper to Bumper Warranty? It is certainly within the 4 year portion. If it is still under 50,000 miles, you should have it checked by your Dealers Service Department, in case there is an underlying issue causing the squeak. That is what our new car warranty is for.
I would not use WD-40. Your Owners Manual lists the preferred type of lubricant in the Maintenance and Specifications section. That would be the section of the manual that also lists the oil and other specifications.
Simple answer, call your dealer service manager for options. Good service manager will provide such advice.Our sun roof sounds super squeaky. Do you think wd40 could safely be applied to tracks? My concern is the rubber gaskets.
You keep resurrecting posts that are years old. LolSimple answer, call your dealer service manager for options. Good service manager will provide such advice.
