Soft close door
Flthc
2018 Continental Reserve. Driver’s door doesn’t soft close but the other doors do. It was working fine until a couple weeks ago. Any suggestions?
Hello Flthc,
Your Soft-Close door cinch motor is not working - as you know.
Do you see a Diagnostic Trouble code in your instrument panel?
I looked in my Service Manual and it says - 'The cinch motor is part of the door latch control module and is not replaceable separately'.
If you can provide a diagnostic trouble code, I can tell you what process the manual says to use in order to check the electrical function.
Richard
There is no trouble code on the instrument panel beside door is ajar. I could hook up my code reader to the computer later today to see if it has a code.
Flthc,
Yes, scan your OBD system for a trouble code.
Also see if your code reader can read body codes. Body codes may not show up in your instrument panel.
Richard
