2003 that just turned 100k, here is everything I have done so far.
-New plugs and Coil packs
-new trans fluid and filter
-four new tires (same issue with previous tires)
-new brakes and rotors
-front end alignment
-swapped driveshaft and u-joints
Problem: I get a vibration in my steering wheel and in my gas pedal when accelerating. The vibration in the steering wheel is mainly at about 45mph and gets more vibration the faster I am going. The vibration in my gas pedal is at about 30mph and more vibration the faster I go. The vibration in the pedal is only felt when I press down on it. I am going to change the rear differential fluid this weekend, but I don't think that would be what is causing it. Any suggestions would be greatly appreciated.
